02-07-2015, 09:11 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Sky Mobile™
Member: 1049764 Status: Offline Sonork: 100.1678585 Thanks Meter: 62 | lg -ku5400 reset screen lock problame -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Connecting to application CPU...OK Checking partition... Checking partition failed! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Connecting to application CPU...OK Checking partition... Checking partition failed! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor).Canceled! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor).Canceled! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor).Canceled! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor).Canceled! 1st i try with 56k with p990 get error Checking partition failed! 2nd il try with 910k not connect plz help... |
02-07-2015, 09:42 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | You should use LG P999 cable with 910k resistor inside. Connect the phone directly to PC motherboard USB port, don't use any USB hubs or PCI USB extention cards, this is important. Try to perform the operation on another PC. Try to use another P999 cable. Also, look here: http://forum.gsmhosting.com/vbb/f799.../#post10612962, http://forum.gsmhosting.com/vbb/f799.../#post10726231. |
05-03-2016, 08:43 | #3 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Pakistan..
Member: 301242 Status: Offline Thanks Meter: 201 | Welcome to Octoplus/Octopus Box LG Software version 2.2.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: Modem Selected model: KU5400 Initializing device...OK Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*5400#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...Canceled! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor).Canceled! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor).Canceled! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor).Canceled! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Connecting to application CPU...OK Checking partition... Checking partition failed! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Connecting to application CPU...OK Checking partition... Checking partition failed! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Connecting to application CPU...OK Checking partition... Checking partition failed! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Connecting to application CPU...OK Checking partition... Checking partition failed! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Connecting to application CPU...OK Checking partition...Failed! Error code: QAZ6CQAWB5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Connecting to application CPU...OK Checking partition...Failed! Error code: QAZ6CQAWB5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Connecting to application CPU...OK Checking partition...Failed! Error code: QAZ6CQAWB5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: Modem Selected model: KU5400 Initializing device...OK Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*5400#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...Canceled! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Connecting to application CPU...OK Checking partition... Checking partition failed! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Connecting to application CPU...OK Checking partition... Checking partition failed! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Connecting to application CPU...OK Checking partition...Failed! Error code: QAZ6CQAWB5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Please, disconnect battery and connect P999 cable (with 910k resistor).Canceled! i also try both 56k and 910k with motherboard usb error. |
05-05-2016, 08:06 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Hello. Please, make sure that You install all drivers according to the Software manual, also make sure that You connect the phone with correct USB cable P999 cable (with 910k resistor), connect the phone directly to USB port of your PC, don't use HUBS. |
