04-21-2014, 06:50 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: all device sell hear
Member: 1627323 Status: Offline Sonork: WhatsApp+8801763009154 Thanks Meter: 481 | lg ku5900 flashing problem [Solved] -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: KU5900 Opening "KU5900_V30I_00.oct"... Please, disconnect battery and connect P999 cable (with 910k resistor).Canceled! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: KU5900 Opening "KU5900_V30I_00.oct"... Please, disconnect battery and connect P999 cable (with 910k resistor). how to boting ? Last edited by Octopus box; 04-21-2014 at 09:04. |
04-21-2014, 06:56 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. To connect the phone, You should use the special LG P999 cable with 910k resistor inside. To write firmware do the next: 1. Select proper device in the list. 2. Select firmware file. 3. Press "Write Firmware" button. 4. Disconnect the battery and connect the special LG P999 cable with 910k resistor inside. Connect the phone directly to PC motherboard USB port - this is important; don't use any USB hubs or PCI USB cards. 5. Follow the Software instructions. |
04-21-2014, 07:02 | #3 (permalink) |
Member: 1627323 Status: Offline Sonork: WhatsApp+8801763009154 Thanks Meter: 481 | Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader... is pass 10 minit but Sending loader... is hang many long time it? |
04-21-2014, 07:27 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Quote:
Btw, what is the problem with your phone? Why do You want to re-flash it? | |
04-21-2014, 07:42 | #5 (permalink) | |
Member: 1627323 Status: Offline Sonork: WhatsApp+8801763009154 Thanks Meter: 481 | Quote:
04-21-2014, 07:53 | #6 (permalink) |
Member: 1627323 Status: Offline Sonork: WhatsApp+8801763009154 Thanks Meter: 481 | Platform: LG Infineon Connection mode: OMAP Selected model: KU5900 Opening "KU5900_V30I_00.oct"... Please, disconnect battery and connect P999 cable (with 910k resistor).OK Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader...OK Initializing flash...OK Writing psi.fls...OK Writing slb.fls...OK Writing AENEAS_FW.fls...OK Writing R375_SIC.fls...OK Connecting to application CPU...OK Writing Partition #0...OK Writing Partition #1...OK Writing Partition #2...OK Writing Partition #3...OK Writing Partition #4...OK Writing Partition #5...OK Writing Partition #6...OK Writing Partition #7...OK Writing Partition #8...OK Writing Partition #9...OK Writing Partition #10...OK Writing Partition #11...OK Writing Partition #12...OK Writing Partition #13...OK Writing Partition #14...OK Writing Partition #15...OK Writing Partition #16...OK Writing Partition #17...OK Writing Partition #18...OK Writing firmware done! Rebooting phone... Disconnected. Please, reboot the phone manually. done |
