07-02-2015, 09:42 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please repeat "Unlock" operation with latest Software version. Post here result and full Software log of the operation. |
07-02-2015, 15:59 | #3 (permalink) |
Freak Poster Join Date: Apr 2009
Member: 1019191 Status: Offline Thanks Meter: 12 | ITS STILL FAILED PLEASE BRO SUPPORT THIS PHONE Welcome to Octoplus/Octopus Box LG Software version 2.0.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM30 Selected model: L23 Reading info... Model ID: LGL23 IMEI: 358380-05-058929-4 Android version: 4.2.2 Battery level: 81% Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ* ÿh°˜ at port COM30 Unlocking... Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "L23_358380050589294_02-07-2015_17-52-23.SEC" Writing security area...OK Switching to Normal mode... Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ* ÿh°˜ at port COM30 Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Phone is still locked after unlock with new software Last edited by Octopus box; 07-02-2015 at 16:37. |
07-17-2015, 06:28 | #5 (permalink) |
Freak Poster Join Date: Apr 2007 Location: viet nam
Member: 484531 Status: Online Thanks Meter: 69 | Checking data...OK Platform: LG Qualcomm Selected port: COM29 Selected model: L23 Reading info... Mode: Emergency Initializing flash...OK SW version: LGL23AT-01-V10e-440-50-MAY-07-2015+0 LAF Version: 1.0 Product ID: PT03S140106001324 IMEI: 358380-05-036431-8 Target operator: KDDI Hardware: rev_10 Unlocking... Skip Read/Write QCN Reading partition...OK Reading security area...OK Backup saved to "L23_358380050364318_17-07-2015_12-23-22.SEC" Writing security area...OK Switching to Normal mode... Found model AAAAANAZ* ÿh°˜ at port COM9 Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Phone is still locked |
07-17-2015, 09:31 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | What exactly You mean by still locked? Phone is requesting the code, or it is not obtaining network? If phone is requesting Unlock Code after You've made Factory Reset, as "Unlock" operation ended - upload Security backup, which was created during the operation and post here download link. We will research the file. If phone is not obtaining Network - write original QCN backup back into the phone and restart it. As phone turns on, wait 2-5 minutes, then try to find and select Network manually. Try to write QCN from the Support Area. |
07-17-2015, 11:24 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please upload "L23_358380050589294_02-07-2015_17-52-23.SEC" Security backup and post here download link. We will check where can be the problem. |
07-19-2015, 02:18 | #9 (permalink) |
Member: 484531 Status: Online Thanks Meter: 69 | L23_358380050364318_16-07-2015_21-41-09 - Download - 4shared L23_358380050364318_17-07-2015_12-23-22 - Download - 4shared Security and QCN BACKUP .thanks sir |
08-15-2015, 13:31 | #10 (permalink) | |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | Quote:
01-12-2016, 16:23 | #13 (permalink) |
No Life Poster Join Date: Jun 2004 Location: egypt cairo - italy roma Age: 40
Member: 68882 Status: Offline Sonork: 1577247 Thanks Meter: 111 | i already done this steps with last version with the same result phone still locked even with fix imei option with the same imei |
01-12-2016, 16:37 | #15 (permalink) |
Member: 68882 Status: Offline Sonork: 1577247 Thanks Meter: 111 | now its done by writing qcn file from support area and got full signal but when i type 2945#*23# it give me (this phone is permanently locked and can not be unlocked ) but phone working now |
