02-22-2017, 11:14 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 47
Member: 120328 Status: Offline Thanks Meter: 243 | LG L23 Need Root for UnlockOctopus LG/Octoplus LG -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM201 Selected model: K330 Reading info... Model ID: LGL23 Incompatible model ID! Canceled! Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM201 Selected model: L23 Reading info... Model ID: LGL23 IMEI: 358380-05-026546-5 Android version: 4.2.2 Battery level: 12% SW Version: LGL2310eCanceled! Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM201 Selected model: L23 Reading info... Model ID: LGL23 IMEI: 358380-05-026546-5 Android version: 4.2.2 Battery level: 12% SW Version: LGL2310e Trying to enable Diagnostics ports... Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM201 Selected model: L23 Reading info... Model ID: LGL23 IMEI: 358380-05-026546-5 Android version: 4.2.2 Battery level: 12% SW Version: LGL2310e Mode: Normal Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM201 Selected model: L23 Reading info... Model ID: LGL23 IMEI: 358380-05-026546-5 Android version: 4.2.2 Battery level: 12% SW Version: LGL2310e Trying to enable Diagnostics ports... Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Failed! Trying to enable Diagnostics ports... Checking root access... Phone is not rooted. Please, root the phone manually! Performed by 2.5.8 Software version. |
02-22-2017, 12:14 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please try to root the phone with: Vroot, Kingoroot, CFAutoroo, Iroot, One click root or any other root method which You can find on your own risk. |
05-16-2017, 21:59 | #3 (permalink) | |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Lg l23 root tutorial Quote:
Download Root File LG Flex KDDI, LGL23 here: Https://www.androidfilehost.com/?fid=23622183712473558 MD5 Code: 1bac31c609dc39b4c8e99b6c9bc3a6bc 1. Installation and preparation - Full Install LG Driver 3.12.3 Enable USB debug by: - Go to settings / About phone / Software information / Tap 7 times on the word Create Number - Back to Settings on Developer Options / Tick on Usb debug (Debug usb) - Connect the computer cab in LG Software mode 2. Root Extract the file: runroot.bat and follow the steps shown in the CMD window Requires USB Debug ready 3. Recovery This recovery is only for LG Flex KDDI, LGL23 has already claimed Root, Extract zip files just run Recovery.exe file and Allow SupperSu (if any) will flash and automatically into Recovery. Download LG KDDI Recovery, LGL23: Https://www.androidfilehost.com/?fid=23622183712473348 MD5: d11cdb5c44109fa6f9328f5623e2f345 | |
The Following User Says Thank You to chipscell25 For This Useful Post: |
05-16-2017, 22:01 | #4 (permalink) | |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | This makes you root without problems Quote:
