04-19-2014, 08:01 | #1 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Viet Nam (VFS)
Member: 1822938 Status: Offline Sonork: 100.1656339 Thanks Meter: 63 | LG L9 p768 death after flash? [Solved] Platform: LG Infineon Connection mode: OMAP Selected model: P768 Opening "BIN_LGP768AT-00-V20a-AME-XXX-MAY-14-2013+0_AP.oct"...OK Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader...OK Initializing flash...OK Writing psi.fls...OK Writing slb.fls...OK Writing AENEAS_FW.fls...OK Writing L6260_SIC.fls...OK Writing L6260_SIC-CDS.fls...OK Connecting to application CPU...OK Erasing gpt1...OK Writing gpt1...OK Erasing u-boot...OK Writing u-boot...OK Erasing boot...OK Writing boot...OK Erasing recovery...OK Writing recovery...OK Erasing misc...OK Writing misc...OK Erasing reserved...OK Writing reserved...OK Erasing system...OK Writing system...OK Erasing persist...OK Writing persist...OK Erasing gpt2...OK Writing gpt2...OK Writing firmware done! Disconnected. The phone hang on sw upgrade logo i remove battery and re-plug Press power on but nothing happen, now, i can't enter swupgrade mode or omap mode Last edited by Octopus box; 04-23-2014 at 07:04. |
04-21-2014, 06:41 | #3 (permalink) |
Member: 1822938 Status: Offline Sonork: 100.1656339 Thanks Meter: 63 | Repair for what ? imei, bluetooth, wifi mac address ? what for ? My phone is death now because flashing file BIN_LGP768AT-00-V20a-AME-XXX-MAY-14-2013+0_AP.oct |
04-21-2014, 15:58 | #6 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Quote:
To repair boot loader, do the next: 1. Power phone OFF. 2. Remove SD and SIM cards from the phone. 3. Install OMAP driver (http://octopusbox.com/files/drivers/...s_OMAP4430.rar). 4. Select "OMAP" connection mode. 5. Select any firmware file for this phone model. 6. Click "Repair" button. 7. Follow software instructions (promts). Also note, not all devices can be repaired by this procedure. If after of repairing it is impossible to write firmware, currently no solution for such devices. | ||
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
04-22-2014, 05:26 | #7 (permalink) |
Member: 1822938 Status: Offline Sonork: 100.1656339 Thanks Meter: 63 | Sorry, i'm click wrong tab, i see it But i got this error Welcome to Octoplus/Octopus Box LG Software version 1.5.2 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P768 Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Connecting...OK Sending preloader...OK Sending loader...OK Opening "P768FULL.oct"...OK Initializing device...Failed! Port busy |
The Following User Says Thank You to goldenfish125 For This Useful Post: |
04-22-2014, 06:23 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Please, fully charge phone's battery by using external charger and try to use another special LG P999 cable with 910 kOhm resistor inside. Connect the cable directly to PC motherboard USB port (this is important), don't use any USB hubs or PCI USB extention cards. Try to perform Repair procedure on another PC. Try to select other firmware file from the Support Area. |
