04-19-2017, 20:23 | #31 (permalink) | |
Freak Poster Join Date: Jan 2005 Location: miami Age: 47
Member: 112190 Status: Offline Thanks Meter: 21 | Quote:
even downgrade to version "5".... which supposed to be the "one"!!!! and still the same signal 2 seconds and nothing else,,, i already search manually,, and change network mode to everything , and still nothing ,I also tried different version of octoplus including the test software of course. best regards linterna1 | |
06-01-2017, 09:05 | #33 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,410 | Hello. Did You open Hidden menu on your phone? You can do it via Software, perform "Open Hidden Menu" operation, then follow these steps: 1. Go to "IOT(CDG2)" -> "LTE Setting" -> "Operation Mode"; 2. Select "Lab Network" option. |
06-05-2017, 13:21 | #36 (permalink) |
Freak Poster Join Date: Aug 2011 Location: New York City
Member: 1637281 Status: Offline Sonork: 100.1657188 Thanks Meter: 95 | Regardless. You will get signal for 2 seconds. I've mentioned it before both octopus refuses to fix it and you lose unlock after factory reset. |
The Following User Says Thank You to concepttheman For This Useful Post: |
06-05-2017, 13:29 | #37 (permalink) | |
Crazy Poster Join Date: Feb 2009
Member: 975482 Status: Offline Thanks Meter: 11 | Quote:
Sent from my LG-H872 using Tapatalk | |
06-08-2017, 20:42 | #40 (permalink) |
Freak Poster Join Date: Oct 2016
Member: 2632431 Status: Offline Thanks Meter: 15 | LG stylo 2 doesnt work domestically over the US, even if you unlock it with gcpro or any other boxes, same issue with the firmware that have it fully unlocked too, it doesnt work over the USA, only data works, no voice but internationally work flawesly |
06-27-2017, 17:41 | #42 (permalink) |
Junior Member Join Date: Aug 2012 Location: El Salvador
Member: 1800581 Status: Offline Sonork: willix1 Thanks Meter: 0 | Hello I hope you can help me I'm having problems with this model I find myself in zv9 version with octopus lg 2.6.8 when I read or unlock me request the code spc ## 3424 # Platform: LG Qualcomm Selected port: COM39 Selected model: LS775 Reading info... IMEI: Android version: 6.0.1 Battery level: 30% SW Version: 24/06/2017 12:42:58 p.m. > LS775ZV5 Mode: Emergency Initializing flash...24/06/2017 12:43:01 p.m. > OK SW version: 24/06/2017 12:43:03 p.m. > LS775ZV9_01 Android version: 7.0 LAF Version: 1.1 Product ID: CT69S161006006277 IMEI: Target operator: SPR Hardware: rev_10 Reading partitions...24/06/2017 12:43:04 p.m. > OK Reading Carrier...24/06/2017 12:56:28 p.m. > OK Unlocking...24/06/2017 12:56:28 p.m. > OK Writing Carrier... LAF Error: 80000121. Trying second method...24/06/2017 01:04:44 p.m. > Failed! Performed by 2.6.8 Software version. Can someone please provide me a beta test link 2.6.0.2 |
06-28-2017, 08:23 | #43 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,410 | We have prepared test Software version for You. Please download and install it from the Support Area ("LG/TEST SOFTWARE" folder), then repeat operation again and post here full Software log. |
07-02-2017, 19:41 | #44 (permalink) | |
Member: 1800581 Status: Offline Sonork: willix1 Thanks Meter: 0 | Quote:
Checking data...29/06/2017 11:48:28 a.m. > OK Platform: LG Qualcomm Selected port: COM20 Selected model: LS775 Reading info... IMEI: Android version: 6.0.1 Battery level: 48% SW Version: 29/06/2017 11:48:31 a.m. > LS775ZV5 Mode: Emergency Initializing flash...29/06/2017 11:48:34 a.m. > OK SW version: 29/06/2017 11:48:36 a.m. > LS775ZVA_04 Android version: 7.0 LAF Version: 1.1 Product ID: CT69S161006006277 IMEI: Target operator: SPR Hardware: rev_10 Reading partitions...29/06/2017 11:48:37 a.m. > OK Reading Carrier...29/06/2017 12:02:08 p.m. > OK Unlocking...29/06/2017 12:02:08 p.m. > OK Writing Carrier... LAF Error: 80000121. Trying second method...29/06/2017 12:26:09 p.m. > OK Phone successfully unlocked! | |
01-13-2018, 14:02 | #45 (permalink) |
Junior Member Join Date: Jul 2013 Location: Bangladesh
Member: 1979369 Status: Offline Thanks Meter: 7 | Welcome to Octoplus/Octopus Box LG Software version 2.7.8 Checking data...OK Platform: LG Qualcomm Selected port: COM21 Selected model: LS775 Reading info... Mode: Emergency Initializing flash...OK SW version: LS775ZV6_04 Android version: 6.0.1 LAF Version: 1.1 Product ID: CY15S160827003505 IMEI: 356304-07-604725-3 Target operator: SPR Hardware: rev_10 Reading partitions...OK Reading Carrier...OK Unlocking...OK Writing Carrier...OK Phone successfully unlocked! Performed by 2.7.8 Software version. br rowshonjaman gsm unlock rj |
