03-29-2017, 09:01 | #32 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please, download and install test Software version form the Support Area (LG/TEST SOFTWARE/), then You can try to perform Repair Network operation. |
03-29-2017, 09:50 | #34 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please, download and install test Software version form the Support Area (LG/TEST SOFTWARE/), then try to perform Repair Network operation. Post here full Software log. |
03-29-2017, 15:27 | #35 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Cuba Age: 36
Member: 1892086 Status: Offline Sonork: 1671742 Thanks Meter: 282 | For APN open hidden menu --> IOT(CDG2) --> LTE setting --> APN Setting --> Hold [] button till you see Create APN |
The Following User Says Thank You to ernestico911 For This Useful Post: |
03-30-2017, 11:02 | #38 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Test Software version is available in "LG/TEST SOFTWARE" folder of the Support Area. To access Support Area, press "Go to support" button on "Support & options" tab of the Software. Also You can use Files Downloader on "Support & options" tab of the Software to browse, search and download files from the Support Area. |
05-12-2017, 23:13 | #39 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Cuba Age: 38
Member: 983297 Status: Offline Thanks Meter: 61 | Succeful !!! but how open hidden menu for create APN ¿ Welcome to Octoplus/Octopus Box LG Software version 2.6.4 (Lite) -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM81 Selected model: LS775 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: LGLS775 Phone firmware version: LGLS775AT-00-ZV9-SPR-US-FEB-02-2017+01 Kernel version: 3.10.49-gcacba2d-00012-g7c02ae4 (lgmobile@LGEACI8R5) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Thu Feb 2 13:27:09 KST 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8916 0 Please, type ##3424# to get SPC / MSL / Service Code...OK Input , go to "Diag" menu and select "Enable" option. Found model LS775ZV9:ÿd at port COM566 Reading info... Model ID: LGLS775 IMEI: 355141-08-243883-2 Android version: 7.0 Battery level: 49% SW Version: LS775ZV9 Mode: Normal Firmware compiled date: Nov 18 2016 Firmware compiled time: 04:00:00 Firmware released date: Feb 2 2017 Firmware released time: 13:31:00 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 355141-08-243883-2 SPC: 164212 MEID: 35514108243883 Mobile ESN: 8070CD47 SSD_A: 0000000000000000 SSD_B: 0000000000000000 OTKSL: 283603 NAM Name: Sprint MDN: 432-307-2634 User Lock Code: 6231 SID/NID: 4139 / 65535 MCC: 310 MNC: 00 MIN1: 2932263 MIN2: 915 Performed by 2.6.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM566 Selected model: LS775 Reading info... IMEI: 355141-08-243883-2 Android version: 7.0 Battery level: 49% SW Version: LS775ZV9 Mode: Normal Firmware compiled date: Nov 18 2016 Firmware compiled time: 04:00:00 Firmware released date: Feb 2 2017 Firmware released time: 13:31:00 SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1 IMEI: 355141-08-243883-2 SPC: 164212 MEID: 35514108243883 Mobile ESN: 8070CD47 SSD_A: 0000000000000000 SSD_B: 0000000000000000 OTKSL: 283603 NAM Name: Sprint MDN: 432-307-2634 User Lock Code: 6231 SID/NID: 4139 / 65535 MCC: 310 MNC: 00 MIN1: 2932263 MIN2: 915 Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading Carrier...OK Unlocking...OK Writing Carrier... LAF Error: 80000121. Trying second method...OK Phone successfully unlocked! Performed by 2.6.4 Software version. |
06-28-2017, 20:31 | #41 (permalink) |
No Life Poster Join Date: Apr 2012 Location: Black Market Age: 39
Member: 1744748 Status: Offline Thanks Meter: 752 | Trying to flash stock rom after FRP cause error booting the device Welcome to Octoplus/Octopus Box LG Software version 2.6.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: LS775 Reading info... IMEI: 350305-26-000000-4 Android version: 6.0.1 Battery level: 84% SW Version: LS775ZV6 Mode: Emergency Initializing flash...OK SW version: LS775ZV9_01 Android version: 7.0 LAF Version: 1.1 Product ID: CY13S161115005627 IMEI: 355141-08-032685-6 Target operator: SPR Hardware: rev_10 Opening "LS775ZV8_07.tot"...OK Firmware version: LS775ZV8 Firmware model: LGLS775 File declared for different phone model! Performed by 2.6.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: LS775 Reading info... IMEI: 350305-26-000000-4 Android version: 6.0.1 Battery level: 86% SW Version: LS775ZV6 Mode: Emergency Initializing flash...OK SW version: LS775ZV9_01 Android version: 7.0 LAF Version: 1.1 Product ID: CY13S161115005627 IMEI: 355141-08-032685-6 Target operator: SPR Hardware: rev_10 Opening "LS775ZV8_07.tot"...OK Firmware version: LS775ZV8 Firmware model: LGLS775 File declared for different phone model! Performed by 2.6.9 Software version. Converting files... Unpacking "PrimaryGPT"...OK Unpacking "sbl1"...OK Unpacking "tz"...OK Unpacking "hyp"...OK Unpacking "rpm"...OK Unpacking "aboot"...OK Unpacking "sbl1bak"...OK Unpacking "tzbak"...OK Unpacking "hypbak"...OK Unpacking "rpmbak"...OK Unpacking "abootbak"...OK Unpacking "persist"...OK Unpacking "metadata"...OK Unpacking "laf"...OK Unpacking "boot"...OK Unpacking "recovery"...OK Unpacking "recoverybak"...OK Unpacking "sec"...OK Unpacking "factory"...OK Unpacking "modem"...OK Unpacking "carrier"...OK Unpacking "system"...OK Unpacking done. Processing files... Identifying sub-files...OK Creating destination file...OK Deleting temporary files... Deleting directory "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \"... Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \aboot"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \abootbak"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \boot"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \carrier"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \factory"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \hyp"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \hypbak"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \laf"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \metadata"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \modem"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \parts.bin"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \persist"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \PrimaryGPT"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \recovery"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \recoverybak"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \rpm"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \rpmbak"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \sbl1"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \sbl1bak"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \sec"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \system"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \tz"...OK Deleting file "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8 _07 \tzbak"...OK Directory "C:\Users\SIMPLY~1\AppData\Local\Temp\LS775ZV8_07\ " succesfully deleted! Firmware convert done! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: LS775 Reading info... IMEI: 350305-26-000000-4 Android version: 6.0.1 Battery level: 87% SW Version: LS775ZV6 Mode: Emergency Initializing flash...OK SW version: LS775ZV9_01 Android version: 7.0 LAF Version: 1.1 Product ID: CY13S161115005627 IMEI: 355141-08-032685-6 Target operator: SPR Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LS775ZV8_07.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...Failed! LAF Error: 80000121. Please, try to reflash your device with higher firmware version, then repeat Reset FRP operation. Performed by 2.6.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: LS775 Reading info... IMEI: 350305-26-000000-4 Android version: 6.0.1 Battery level: 87% SW Version: LS775ZV6 Mode: Emergency Initializing flash...OK SW version: LS775ZV9_01 Android version: 7.0 LAF Version: 1.1 Product ID: CY13S161115005627 IMEI: 355141-08-032685-6 Target operator: SPR Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LS775ZV8_07.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...Failed! LAF Error: 80000121. Please, try to reflash your device with higher firmware version, then repeat Reset FRP operation. Performed by 2.6.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: LS775 Reading info... IMEI: 350305-26-000000-4 Android version: 6.0.1 Battery level: 91% SW Version: LS775ZV6 Mode: Emergency Initializing flash...OK SW version: LS775ZV9_01 Android version: 7.0 LAF Version: 1.1 Product ID: CY13S161115005627 IMEI: 355141-08-032685-6 Target operator: SPR Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LS775ZV8_07.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...Failed! LAF Error: 80000121. Please, try to reflash your device with higher firmware version, then repeat Reset FRP operation. Performed by 2.6.9 Software version. |
06-28-2017, 20:45 | #42 (permalink) |
Member: 1892086 Status: Offline Sonork: 1671742 Thanks Meter: 282 | I dont know what is your problem, look at this log, already FRP done with out problem Checking data...OK Platform: LG Qualcomm Selected port: COM233 Selected model: LS775 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... IMEI: 356304-XX-XXXXXX-X Android version: Battery level: 34% SW Version: LS775ZV8 Mode: Emergency Initializing flash...OK SW version: LS775ZV8_07 Android version: 7.0 LAF Version: 1.1 Product ID: IMEI: 356304-XX-XXXXXX-X Target operator: SPR Hardware: rev_10 Reset FRP operation for LS775 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock... Writing loader...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.6.9 Software version. |
