07-08-2019, 14:48 | #1 (permalink) |
Freak Poster Join Date: Dec 2014 Location: NIGERIA
Member: 2312129 Status: Offline Thanks Meter: 139 | Lg ls777 unlock issue Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: LS777 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.9.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: LS777 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.9.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: LS777 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...OK Model ID: LG-LS777 Phone firmware version: LGLS777AT-00-ZVF-SPR-US-SEP-04- 2018-ARB02+01 Short firmware version: ZVF Kernel version: 3.18.31-perf-g74ac7f0-00001-g4d89e29 (lgmobile@sbs25) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Tue Sep 4 16:33:29 CST 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8940 0 Unlock operation is currently not supported for your phone's firmware. Sending exploit...OK Executing exploit...OK Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 2.9.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: LS777 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.9.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM168 Selected model: LS777 Reading info... IMEI: 350305-26-000000-4 Android version: 7.0 Battery level: 80% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LS777ZVF_01 Android version: 7.0 LAF Version: 1.1 Product ID: VS05S170830001486 IMEI: 354234-08-371040-7 Target operator: SPR Hardware: rev_10 Switching to Normal mode... Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Please, root the phone manually! Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Please, root the phone manually! Performed by 2.9.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: LS777 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...OK Model ID: LG-LS777 Phone firmware version: LGLS777AT-00-ZVF-SPR-US-SEP-04- 2018-ARB02+01 Short firmware version: ZVF Kernel version: 3.18.31-perf-g74ac7f0-00001-g4d89e29 (lgmobile@sbs25) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Tue Sep 4 16:33:29 CST 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8940 0 Unlock operation is currently not supported for your phone's firmware. Sending exploit...OK Executing exploit...OK Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 2.9.5 Software version. At first device was showing invalid sim after this opration it started showing network locked i have i think unlocked this device without stress since i am having this issue i am thinking of downgrading it but i still like to hear you out if it will be risky to downgrade BEST REGARD OCTOPLUSE TEAM |
07-08-2019, 15:50 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
