01-14-2018, 07:19 | #1 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | LG LS777 unlocking problem [Answered] try everything but give eorror........ not unlock with open hidden menu as well hidden menu open but ioa option is not there ... Welcome to Octoplus/Octopus Box LG Software version 2.7.8 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM7 Selected model: LS777 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.7.8 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM7 Selected model: LS777 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.7.8 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM7 Selected model: LS777 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...OK Model ID: LG-LS777 Phone firmware version: LGLS777AT-00-ZV9-SPR-US-NOV-24-2017-ARB02+00 Kernel version: 3.18.31-perf-g1711dce73f03 (lgmobile@sbs23) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Fri Nov 24 11:23:00 CST 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8940 0 Please, type ##3424# to get SPC / MSL / Service Code...Failed! Performed by 2.7.8 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM7 Selected model: LS777 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...OK Model ID: LG-LS777 Phone firmware version: LGLS777AT-00-ZV9-SPR-US-NOV-24-2017-ARB02+00 Kernel version: 3.18.31-perf-g1711dce73f03 (lgmobile@sbs23) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Fri Nov 24 11:23:00 CST 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8940 0 Please, type ##3424# to get SPC / MSL / Service Code...Failed! Performed by 2.7.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM7 Selected model: LS777 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...OK Model ID: LG-LS777 Phone firmware version: LGLS777AT-00-ZV9-SPR-US-NOV-24-2017-ARB02+00 Kernel version: 3.18.31-perf-g1711dce73f03 (lgmobile@sbs23) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Fri Nov 24 11:23:00 CST 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8940 0 Sending exploit...OK Executing exploit...OK Opening Hidden Menu...OK Performed by 2.7.8 Software version. Last edited by Octopus box; 01-27-2018 at 10:18. |
01-15-2018, 09:13 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please, try to put the phone into Emergency Mode manually, after perform Unlock operation, post here full Software log. |
01-23-2018, 08:52 | #4 (permalink) |
Major Poster Join Date: Mar 2010 Location: Miami, Fl
Member: 1254395 Status: Offline Thanks Meter: 4 | Well, I used your last test software on my zv8 LS777, and they changed from Invalid sim to Network Locked, at least it shows some advance. Any ideas to keep trying? |
01-27-2018, 03:08 | #6 (permalink) |
Member: 1254395 Status: Offline Thanks Meter: 4 | This is done with the Test Software, after ran it, it changed the message from invalid sim to network locked, nothing else changed. Imei, SN, everything is correct. Welcome to Octoplus/Octopus Box LG Software version 2.7.8.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM18 Selected model: LS777 Reading info... IMEI: 350305-26-000000-4 Android version: 7.0 Battery level: 100% SW Version: LS777ZV8 Mode: Emergency Initializing flash...OK SW version: LS777ZV8_06 Android version: 7.0 LAF Version: 1.1 Product ID: VS06S171031006929 IMEI: 354234-08-686330-2 Target operator: SPR Hardware: rev_10 Unlock operation is currently not supported for your phone's firmware. Reading partitions...OK Reading Carrier...OK Unlocking...OK Writing Carrier... LAF Error: 80000121. Trying second method...OK Phone successfully unlocked! Performed by 2.7.8.1 Software version. |
01-27-2018, 10:17 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | As You can see from your Software log: Quote:
02-08-2018, 01:01 | #8 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2693765 Status: Offline Thanks Meter: 3 | Bienvenido en Octoplus/Octopus Box LG Software version 2.7.8 -------------------------------------------------------------------------------- Checking data...OK Plataforma: LG Qualcomm Puerto seleccionado: COM722 Modelo seleccionado: LS777 Lectura de la información... IMEI: 350305-26-000000-4 Android version: 7.0 Battery level: 22% Versión de SW: LS777ZV3 Mode: Emergency Initializing flash...OK Versión de SW: LS777ZV9_00 Android version: 7.0 LAF Version: 1.1 Product ID: CD29S170219001892 IMEI: 354234-08-099356-8 Target operator: SPR Hardware: rev_10 Unlock operation is currently not supported for your phone's firmware. Performed by 2.7.8 Software version. -------------------------------------------------------------------------------- Plataforma: LG Qualcomm Puerto seleccionado: COM722 Modelo seleccionado: LS777 Lectura de la información... IMEI: 350305-26-000000-4 Android version: 7.0 Battery level: 22% Versión de SW: LS777ZV3 Mode: Emergency Initializing flash...OK Versión de SW: LS777ZV9_00 Android version: 7.0 LAF Version: 1.1 Product ID: CD29S170219001892 IMEI: 354234-08-099356-8 Target operator: SPR Hardware: rev_10 Performed by 2.7.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Plataforma: LG Qualcomm Puerto seleccionado: COM722 Modelo seleccionado: LS777 Lectura de la información... IMEI: 350305-26-000000-4 Android version: 7.0 Battery level: 22% Versión de SW: LS777ZV3 Mode: Emergency Initializing flash...OK Versión de SW: LS777ZV9_00 Android version: 7.0 LAF Version: 1.1 Product ID: CD29S170219001892 IMEI: 354234-08-099356-8 Target operator: SPR Hardware: rev_10 Unlock operation is currently not supported for your phone's firmware. Performed by 2.7.8 Software version. |
02-08-2018, 07:38 | #9 (permalink) | |
02-11-2018, 07:08 | #10 (permalink) | |
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | Quote:
we have to wait for next update may be later become supported :P | |
03-02-2018, 20:24 | #11 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Gambia
Member: 1440837 Status: Offline Sonork: 3535 Thanks Meter: 47 | Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM687 Selected model: LS777 Reading info... IMEI: 354234-08-643690-1 Android version: 7.0 Battery level: 80% SW Version: LS777ZV9 Mode: Normal Firmware compiled date: Sep 07 2017 Firmware compiled time: 23:00:00 Firmware released date: Nov 24 2017 Firmware released time: 11:22:45 SW Version: MPSS.TA.2.3.c4-00002-8940_GEN_PACK- 1.84083.1.115268.1 IMEI: 354234-08-643690-1 SPC: 712188 MEID: 35423408643690 Mobile ESN: 801E9217 SSD_A: 0000000000000000 SSD_B: 0000000000000000 OTKSL: 856411 NAM Name: Sprint User Lock Code: 7127 Unlock operation is currently not supported for your phone's firmware. Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading Carrier...OK Unlocking...OK Writing Carrier... LAF Error: 80000121. Trying second method...Failed! LAF Error: 00000000. Unlock operation is currently not supported for your phone's firmware. Performed by 2.8.0 Software version. |
03-04-2018, 08:18 | #13 (permalink) | |
already mention not supported this version at the moment | |
The Following User Says Thank You to lerner_ For This Useful Post: |
