02-11-2015, 20:53 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Lahore
Member: 392149 Status: Offline Thanks Meter: 199 | LG LS980 can work? Last edited by Octopus box; 04-15-2015 at 06:11. |
02-11-2015, 21:18 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Disconnect all other devices from PC, re-boot the PC, re-start the phone, turn on USB Debugging Mode in the phone, go to "Settings->PC connection->Select USB connection method" and select "Charge phone" option. Then try to connect the phone again and post here full Software log. Note: To connect the phone in Normal Mode, do the next: Type ##3424#, go to "Diag" menu and select "Enable". This menu is blocked by SPC/MSL code. This code is given by phone's provider. |
02-12-2015, 10:33 | #3 (permalink) | |
Member: 392149 Status: Offline Thanks Meter: 199 | Quote:
02-12-2015, 11:18 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Which device and wich ports exactly appear in PC Device Manager, when You connect the phone to PC? Which operations do You want to perform with the device? |
02-12-2015, 12:37 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | To Repair IMEI, phone should be connected in Normal Mode via diagnostic (serial) port. If the code ##3424# doesn't work, try to re-flash the phone with another firmware and check ##3424# again, currently we don't know other way, how to enable diagnostic (serial) port in this device. |
02-12-2015, 12:49 | #9 (permalink) | |
02-13-2015, 14:43 | #12 (permalink) | |
here is logs Welcome to Octoplus/Octopus Box LG Software version 1.8.4 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM100 Selected model: LS980 Reading info...OK Mode: Emergency Initializing flash...OK Model ID: LG-LS980 SW version: LS980ZV8_13 LAF Version: 1.0 Product ID: YE03S140319002033 IMEI: 990002-52-710857-3 Target operator: SPR Hardware: rev_10 Battery level: 44% Opening "LS980ZVC_12.oct"...OK Setting options...OK Reading partition...OK Formating USERDATA...OK Writing @赻e״;͂˝θ ...Failed! | |
