03-09-2017, 11:21 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: India
Member: 481609 Status: Offline Sonork: 100.1659889 Thanks Meter: 367 | lg ls980 service disabled done Checking data...OK Platform: LG Qualcomm Selected port: COM479 Selected model: LS980 Reading info... Model ID: LG-LS980 IMEI: 350305-26-000000-4 Android version: 4.4.2 Battery level: 100% SW Version: LS980ZVC Mode: Normal Firmware compiled date: Feb 25 2014 Firmware compiled time: 20:00:00 Firmware released date: Mar 9 2014 Firmware released time: 11:36:00 SW Version: M8974A-AAAANAZM-2.0.20046 IMEI: 3xxxxxxxxxx4 SPC: 000000 MEID: 3xxxxxxxxxxx Mobile ESN: 808D1BB1 NAM Name: Sprint MDN: 817-939-0631 User Lock Code: 0631 SID/NID: 4139 / 65535 MCC: 310 MNC: 00 MIN1: 7079650 MIN2: 817 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LS980ZV8_13.51097.oct"...OK Switching to Download mode...OK Initializing flash...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM49 Selected model: LS980 Reading info...Failed! Port busy Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM49 Selected model: LS980 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...OK Model ID: LG-LS980 Phone firmware version: LS980ZV8_13 Kernel version: 3.4.0-perf-g1fe3c70 (lgmobile@LGEARND4B12) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Nov 26 11:25:38 KST 201 Android version: 4.2.2 Hardware: Qualcomm MSM 8974 (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Checking root access... Phone is not rooted. Sending exploit...Failed! Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM49 Selected model: LS980 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...OK Model ID: LG-LS980 Phone firmware version: LS980ZV8_13 Kernel version: 3.4.0-perf-g1fe3c70 (lgmobile@LGEARND4B12) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Nov 26 11:25:38 KST 201 Android version: 4.2.2 Hardware: Qualcomm MSM 8974 (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Please, type ##3424# to get SPC / MSL / Service Code...Failed! Unlocking... Checking root access... Phone is already rooted. Sending network config...OK Setting options...OK Phone successfully unlocked! Rebooting phone... Performed by 2.5.8 Software version. |
The Following 2 Users Say Thank You to ali_imran For This Useful Post: |
