07-06-2014, 10:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2014
Member: 2108593 Status: Offline Thanks Meter: 839 | Lg-lu6200 service disabled 7/6/2014 1:48:52 PM > Searching Diagnostic Ports...7/6/2014 1:48:52 PM > OK 7/6/2014 1:48:52 PM > -------------------------------------------------------------------------------- 7/6/2014 1:48:52 PM > Platform: LG Qualcomm 7/6/2014 1:48:52 PM > Selected port: COM7 7/6/2014 1:48:52 PM > Selected model: LU6200 7/6/2014 1:48:52 PM > Reading info...7/6/2014 1:48:52 PM > Failed! 7/6/2014 1:48:52 PM > Port busy 7/6/2014 1:56:56 PM > Searching Diagnostic Ports...7/6/2014 1:56:56 PM > OK 7/6/2014 1:56:56 PM > -------------------------------------------------------------------------------- 7/6/2014 1:56:56 PM > Platform: LG Qualcomm 7/6/2014 1:56:56 PM > Selected port: COM23 7/6/2014 1:56:56 PM > Selected model: LU6200 7/6/2014 1:56:56 PM > Reading info...7/6/2014 1:56:57 PM > OK 7/6/2014 1:56:57 PM > Mode: Normal 7/6/2014 1:56:57 PM > Firmware compiled date: Jun 12 2013 7/6/2014 1:56:57 PM > Firmware compiled time: 09:10:05 7/6/2014 1:56:57 PM > Firmware released date: Jun 12 2013 7/6/2014 1:56:57 PM > Firmware released time: 09:10:05 7/6/2014 1:56:57 PM > SW Version: M9600B-SCAQSVZD-3.6.266 7/6/2014 1:56:57 PM > Switching to Serial Port... 7/6/2014 1:56:57 PM > Found port COM24 7/6/2014 1:56:57 PM > Searching Diagnostic Ports...7/6/2014 1:56:57 PM > OK 7/6/2014 1:56:57 PM > Switching to Serial Port... 7/6/2014 1:56:57 PM > Found port COM24 7/6/2014 1:56:57 PM > Searching Diagnostic Ports...7/6/2014 1:56:57 PM > OK 7/6/2014 1:56:57 PM > Unlocking... 7/6/2014 1:56:57 PM > Reading NVM...7/6/2014 1:59:10 PM > OK 7/6/2014 1:59:10 PM > Backup saved to "LU6200_Bad_06-07-2014_13-56-57.NVM" 7/6/2014 1:59:10 PM > Switching to Serial Port... 7/6/2014 1:59:10 PM > Found port COM24 7/6/2014 1:59:10 PM > Switching to Download mode...7/6/2014 1:59:30 PM > OK 7/6/2014 1:59:30 PM > Initializing flash...7/6/2014 1:59:30 PM > OK 7/6/2014 1:59:30 PM > Reading partition...7/6/2014 1:59:31 PM > OK 7/6/2014 1:59:31 PM > Searching security area...7/6/2014 1:59:31 PM > OK 7/6/2014 1:59:31 PM > Reading security area...7/6/2014 1:59:38 PM > OK 7/6/2014 1:59:38 PM > Backup saved to "LU6200_Bad_06-07-2014_13-59-31.SEC" 7/6/2014 1:59:47 PM > Analyzing security...7/6/2014 1:59:52 PM > OK 7/6/2014 1:59:52 PM > Switching to Normal mode... 7/6/2014 2:01:12 PM > Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect cable and press "Ok" button 7/6/2014 2:01:30 PM > Found model SCAQSVZQ* ÿd at port COM23 7/6/2014 2:01:35 PM > Searching Diagnostic Ports...7/6/2014 2:01:35 PM > OK 7/6/2014 2:01:35 PM > Checking data...7/6/2014 2:01:35 PM > OK 7/6/2014 2:01:35 PM > Writing NVM...7/6/2014 2:01:36 PM > OK 7/6/2014 2:01:36 PM > NVM succesfully repaired. 7/6/2014 2:01:36 PM > Phone successfully unlocked! 7/6/2014 2:01:36 PM > Switching to Serial Port... 7/6/2014 2:01:36 PM > Found port COM24 7/6/2014 2:01:36 PM > Internal error! Error code: Z1AL3CAS2Q |
07-08-2014, 09:02 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Do the next: 1. Fully charge phone's battery by using external charger. 2. Re-flash the phone with the firmware from the Support Area. 3. Make Unlock again. 4. Post here the result. |
