08-13-2019, 23:50 | #1 (permalink) |
Freak Poster Join Date: Jul 2015 Location: London
Member: 2429925 Status: Offline Thanks Meter: 17 | Lg m-x210apm error [Answered] -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: LMX210APM Reading info... Model ID: LM-X210APMX210APM20e IMEI: 355437-10-154247-5 Android version: 8.1.0 Battery level: 57% Mode: Normal Firmware compiled date: Sep 10 2018 Firmware compiled time: 09:00:00 Firmware released date: Apr 4 2019 Firmware released time: 10:58:45 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK-1 IMEI: 355437-10-154247-5 Bluetooth address: AC:F6:F7:2D:9B:90 Wi-Fi MAC address: 64:C2E:98:0E:7E SPC: 000000 Unlocking... Initializing ADB...OK Waiting for phone...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: odane23smith Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 112 credits. To perform "Unlock" operation you need to have 50 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Reading security area...Failed! LAF Error: 80000119. Writing security area... LAF Error: 80000121. Trying second method...Failed! LAF Error: 00000000. Unlock operation is currently not supported for your phone's firmware. Error code: ZXCSIMMISC Performed by 2.9.5 Software version. Connecting to server support2.octoplusbox.com:82...OK Authorizing...OK CAN this phone firmware be downgraded back to android 7 for possible unlock ? i"ve been getting lots these phones for unlock an there's no unlock from octoplus LG OR OCTOPLUS SUITE FOR LG CODE SEARCH |
08-14-2019, 21:22 | #3 (permalink) |
Member: 2429925 Status: Offline Thanks Meter: 17 | Welcome to Octoplus/Octopus Box LG Software version 2.9.5.06 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM21 Selected model: LMX210APM Reading info... Model ID: LM-X210APMX210APM20e IMEI: 355437-10-154247-5 Android version: 8.1.0 Battery level: 51% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20e-310-410-APR-04-2019- ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VP01S190509004651 IMEI: 355437-10-154247-5 Target operator: ATT Hardware: rev_10 Unlocking... Switching to Normal mode... Found model LMX210AP: ÿh at port COM19 Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: odane23smith Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 272 credits. To perform "Unlock" operation you need to have 50 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Reading security area...Failed! LAF Error: 80000119. Writing security area... LAF Error: 80000121. Trying second method...Failed! LAF Error: 00000000. Unlock operation is currently not supported for your phone's firmware. Error code: ZXCSIMMISC Performed by 2.9.5.06 Software version. |
08-14-2019, 22:12 | #4 (permalink) |
Member: 2429925 Status: Offline Thanks Meter: 17 | Welcome to Octoplus/Octopus Box LG Software version 2.9.5.06 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM7 Selected model: LMX210APM Reading info... Could not detect mode! Performed by 2.9.5.06 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM19 Selected model: LMX210APM Reading info... Model ID: LM-X210APMX210APM20e IMEI: 355437-10-154247-5 Android version: 8.1.0 Battery level: 52% Mode: Normal Firmware compiled date: Sep 10 2018 Firmware compiled time: 09:00:00 Firmware released date: Apr 4 2019 Firmware released time: 10:58:45 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK-1 IMEI: 355437-10-154247-5 Bluetooth address: AC:F6:F7:2D:9B:90 Wi-Fi MAC address: 64:C2E:98:0E:7E SPC: 000000 Performed by 2.9.5.06 Software version. |
08-15-2019, 09:02 | #5 (permalink) | ||
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello. Quote:
The Following User Says Thank You to Octopus support For This Useful Post: |
