08-05-2017, 15:59 | #1 (permalink) |
No Life Poster Join Date: May 2007 Age: 40
Member: 515130 Status: Offline Thanks Meter: 304 | LG M150G unlock problem -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM13 Selected model: M160 Reading info... Could not detect mode! Performed by 2.7.1 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM13 Selected model: M160 Reading info... Could not detect mode! Performed by 2.7.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: M150AT Reading info... Could not detect mode! Performed by 2.7.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: M150AT Reading info... Could not detect mode! Performed by 2.7.1 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM13 Selected model: M150AT Reading info... Could not detect mode! Performed by 2.7.1 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM13 Selected model: M150AT Reading info... Could not detect mode! Performed by 2.7.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: M150AT Reading info... Could not detect mode! Performed by 2.7.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: M150AT Reading info... Could not detect mode! Performed by 2.7.1 Software version. |
08-05-2017, 16:11 | #2 (permalink) |
Member: 515130 Status: Offline Thanks Meter: 304 | now i try download mode but phone ask root how to root Welcome to Octoplus/Octopus Box LG Software version 2.7.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM23 Selected model: M160 Reading info... Model ID: LG-M150 IMEI: 000000-00-000000-0 Android version: 6.0.1 Battery level: 16% SW Version: M15010g Mode: Emergency Initializing flash...OK SW version: LGM150AT-01-V10g-310-410-JAN-25-2017-ARB00+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB41S170521003569 IMEI: 354063-08-413087-1 Target operator: ATT Hardware: rev_10 Unlocking... Switching to Normal mode... Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port...Failed! Trying to enable Diagnostics ports... Checking root access... Phone is not rooted. Please, root the phone manually! Performed by 2.7.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: M150AT Reading info... Could not detect mode! Performed by 2.7.1 Software version. |
08-05-2017, 19:25 | #3 (permalink) | |
No Life Poster Join Date: Mar 2016 Location: MWA
Member: 2541648 Status: Offline Thanks Meter: 166 | Quote:
08-07-2017, 08:01 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. To unlock the phone please do the next: 1. Connect the phone in Normal Mode directly to PC. 2. Select "File transfer" mode in "Use USB connection for" window, then press "Always". 3. Select M150 model in Software. 4. Press "Unlock" button in Software. Post here the result. |
