11-21-2018, 22:45 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: USA Age: 39
Member: 180148 Status: Offline Thanks Meter: 48 | LG M153 Cricket Unlock problem [Answered] PLS help me Octopus team. at least to recover IMEI: LOG : Checking data...OK Platform: LG Qualcomm Selected port: COM61 Selected model: M153 Reading info... Model ID: LG-M153 IMEI: 353431-09-xxxxxx-3 Android version: 6.0.1 Battery level: 65% SW Version: M15311d Mode: Normal Firmware compiled date: Apr 03 2017 Firmware compiled time: 01:00:00 Firmware released date: Dec 5 2017 Firmware released time: 15:04:34 SW Version: MPSS.JO.2.0.c1.2-00026-8909_GEN_PACK-1 IMEI: 353431-09-962525-3 Bluetooth address: 00:3D:E8:6438 Wi-Fi MAC address: 00:3D:E8C:7A:59 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "M153_3534310xxxxxxx3_21-11-2018_15-26-27.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Reading security area...OK Backup saved to "M153_3534310xxxxxxxx3_21-11-2018_15-32-09.SEC" Writing security area...OK Switching to Normal mode... Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port...Failed! Trying to enable Diagnostics ports... Checking root access... Phone is not rooted. Please, root the phone manually! Performed by 2.8.8 Software version. Last edited by Octopus box; 11-22-2018 at 06:09. |
11-22-2018, 06:08 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please write back Security backup "M153_3534310xxxxxxxx3_21-11-2018_15-32-09.SEC" and QCN backup "M153_3534310xxxxxxx3_21-11-2018_15-26-27.qcn". Then repeat the unlock operation using the latest Software version from the Support Area (here is direct lick for You: https://drive.google.com/open?id=1It...BWjf1Ry82KzPUe). Also when connect the device You need to select "File transfer" mode"and press "ALWAYS" - this is important to successfully perform the operation! Last edited by Octopus box; 11-22-2018 at 08:54. |
