09-29-2017, 23:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | LG M154 Reset FRP done -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: LS775 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: LS775 Reading info... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM684 Selected model: LS775 Reading info... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM87 Selected model: LS775 Reading info... IMEI: 350305-26-000000-4 Android version: 6.0.1 Battery level: 60% SW Version: LS775ZV4 Mode: Emergency Initializing flash...OK SW version: LS775ZV6_04 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT68S160809000892 IMEI: 356304-07-489606-5 Target operator: SPR Hardware: rev_10 Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM87 Selected model: LS775 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... IMEI: 350305-26-000000-4 Android version: 6.0.1 Battery level: 60% SW Version: LS775ZV4 Mode: Emergency Initializing flash...OK SW version: LS775ZV6_04 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT68S160809000892 IMEI: 356304-07-489606-5 Target operator: SPR Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! Reading partitions...OK Resetting FRP Lock... Step 1...OK Step 2...OK Step 3...OK Resetting FRP lock successfully completed! Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM87 Selected model: M154 Reading info... Model ID: LG-M154 IMEI: 000000-00-000000-0 Android version: 6.0.1 Battery level: 38% SW Version: M15410b Mode: Emergency Initializing flash...OK SW version: LGM154AT-00-V10b-310-150-JAN-12-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB52S170309001480 IMEI: 355171-08-001888-0 Target operator: CRK Hardware: rev_10 Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM87 Selected model: M154 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M154 IMEI: 000000-00-000000-0 Android version: 6.0.1 Battery level: 38% SW Version: M15410b Mode: Emergency Initializing flash...OK SW version: LGM154AT-00-V10b-310-150-JAN-12-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB52S170309001480 IMEI: 355171-08-001888-0 Target operator: CRK Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... LAF Error: 80000121. Trying second method...OK Resetting FRP lock successfully completed! Performed by 2.7.6 Software version. Last edited by Octopus box; 09-30-2017 at 07:47. |
The Following User Says Thank You to maxpatri9 For This Useful Post: |
