06-29-2018, 11:42 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: BiH
Member: 825846 Status: Offline Sonork: kalaba Thanks Meter: 23 | LG M250n after unlock emergency calls only [Answered] Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM4 Selected baudrate: 921600 Selected model: M250N Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM112 Mode: Emergency Initializing flash...OK Model ID: LG-M250n SW version: LGM250nAT-00-V13c-GLOBAL-COM-APR-27-2018+0 LAF Version: 1.1 Product ID: CY12S170825001437 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 354945-08-113883-4 Bluetooth address: 10:F1:F2:AA:3E:57 Wi-Fi MAC address: 10:F1:F2:27:A1:41 SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "M250N_354945081138834_29-06-2018_12-39-10.EEP" Unlocking... Writing security area...OK Phone successfully unlocked! Performed by 2.8.6 Software version. Last edited by Octopus box; 06-29-2018 at 12:12. |
06-29-2018, 12:11 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. The problem may be with your device, not with the "Unlock" operation. Try to write security backup "M250N_354945081138834_29-06-2018_12-39-10.EEP" back to the phone to return the device to it's previous state in which it was before unlocking, then preform "Read Codes" operation and enter necessary code to unlock the device. Then check network and post here the result. |
06-29-2018, 14:57 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | So the problem not with "Unlock" operation or phone's security. What is the IMEI in your device by *#06#? Try to re-flash the phone and check network again. If the problem is the same, probably device has HW issue(s). |
