03-02-2015, 18:25 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1756668 Status: Offline Thanks Meter: 4 | Lg ms395 [Solved] -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM6 Selected model: MS395 Reading info...Failed! Port busy -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM8 Selected model: MS395 Reading info...OK Mode: Normal Model ID: MS395 Firmware compiled date: Jul 21 2014 Firmware compiled time: 11:00:00 Firmware released date: Sep 14 2014 Firmware released time: 10:30:25 SW Version: MPSS.DI.2.0.1.c1.15-00021-M8926DAAAANAZM-1 SPC: 000000 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: MS395 Reading info...OK Mode: Normal Model ID: MS395 Firmware compiled date: Jul 21 2014 Firmware compiled time: 11:00:00 Firmware released date: Sep 14 2014 Firmware released time: 10:30:25 SW Version: MPSS.DI.2.0.1.c1.15-00021-M8926DAAAANAZM-1 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "MS395_Bad_02-03-2015_10-55-40.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "MS395_Bad_02-03-2015_10-59-23.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect cable and press "Ok" buttonFailed! -------------------------------------------------------------------------------- The phone automatically restarts into normal mode, why do you require that restart in normal mode and it keeps failing.. Last edited by Octopus box; 03-21-2015 at 09:01. |
03-02-2015, 18:32 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Repeat the operation. When switching to Normal Mode will be required - disconnect the phone from PC and wait until the phone will power on. Then connect the phone directly to PC, wait until drivers for all devices will be installed and press "Ok" button. |
03-02-2015, 20:31 | #3 (permalink) | |
Member: 1756668 Status: Offline Thanks Meter: 4 | Quote:
03-20-2015, 16:50 | #5 (permalink) | |
Platform: LG Qualcomm Selected port: COM108 Selected model: MS395 Reading info...OK Mode: Normal Model ID: MS395 Firmware compiled date: Jul 21 2014 Firmware compiled time: 11:00:00 Firmware released date: Sep 14 2014 Firmware released time: 10:30:25 SW Version: MPSS.DI.2.0.1.c1.15-00021-M8926DAAAANAZM-1 SPC: 000000 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM108 Selected model: MS395 Reading info...OK Mode: Normal Model ID: MS395 Firmware compiled date: Jul 21 2014 Firmware compiled time: 11:00:00 Firmware released date: Sep 14 2014 Firmware released time: 10:30:25 SW Version: MPSS.DI.2.0.1.c1.15-00021-M8926DAAAANAZM-1 SPC: 000000 Fixing IMEI... New IMEI: 355197-06-XXXXXX-4 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "MS395_Bad_20-03-2015_10-35-22.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "MS395_Bad_20-03-2015_10-40-36.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect cable and press "Ok" buttonFailed! -------------------------------------------------------------------------------- The phone automatically reboots and I get the message to put the phone in normal mode... The phone is already in normal mode..... Do I need to turn tethering back on? | |
03-20-2015, 17:13 | #6 (permalink) |
Member: 1756668 Status: Offline Thanks Meter: 4 | *** Just to update you... I got this to work by doing the following: 1. You must have the original sim card that came with the phone in order to enable tethering.. If the sim card isn't in the phone then you cannot enable tethering and the phone will not be detected by the Octopus Software.. When the software asks you to disconnect the cable and put it in normal mode you must wait for a signal and then re-enable tethering and then click on OK... Otherwise the process will fail. |
The Following User Says Thank You to aaydah76 For This Useful Post: |
