11-19-2014, 16:15 | #1 (permalink) |
Freak Poster Join Date: Jun 2011 Location: colombia
Member: 1603212 Status: Offline Thanks Meter: 26 | lg ms659 error firware not tried everything goes from here -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM35 Selected model: MS659 Reading info...OK Mode: Emergency Model ID: BS/MS659/003740 SW version: LGMS659AT-02-V10b-310-260-JUN-13-2013+0 Product ID: SM01S130712010375 IMEI: 013687-00-080486-3 Opening "LGMS659AT-01-V10b-310-260-JUN-13-2013+0.oct"...OK Initializing flash...OK Reading partition...OK Formating userdata...OK Writing modem...Failed! Error code: ZXLCALSZXD |
11-19-2014, 16:40 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please check your PM, we have sent You test Software version. Try to perform "Write Firmware" operation with this Software and post here full Software log of the operation. |
11-19-2014, 17:18 | #3 (permalink) |
Member: 1603212 Status: Offline Thanks Meter: 26 | I still have the same problem with the last vercion I do not understand before flashing came out with success Checking data ... OK Platform: LG Qualcomm Selected port: COM35 Selected model: MS659 OK Reading info ... Mode: Emergency Model Number: BS / MS659 / 003 740 SW version: LGMS659AT-V10b-310-260 02-JUN-13-2013 + 0 Product ID: SM01S130712010375 IMEI: 013687-00-080486-3 Opening "LGMS659AT-01-V10b 310-260 JUN-13-2013 + 0.oct" ... OK Initializing flash ... OK Partition ... OK Reading Formating userdata ... OK Writing modem ... Failed! Error code: ZXLCALSZXD |
11-19-2014, 18:02 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We have prepared new test Software version for You, please check PM. Try to perform "Write Firmware" operation and post full Software log here. |
11-19-2014, 18:19 | #5 (permalink) |
Member: 1603212 Status: Offline Thanks Meter: 26 | Checking data...OK Platform: LG Qualcomm Selected port: COM110 Selected model: MS659 Reading info...OK Mode: Emergency Model ID: BS/MS659/003740 SW version: LGMS659AT-02-V10b-310-260-JUN-13-2013+0 Product ID: SM01S130712010375 IMEI: 013687-00-080486-3 Opening "LGMS659AT-01-V10b-310-260-JUN-13-2013+0.oct"...OK Initializing flash...OK Writing PrimaryGPT...Failed! Error code: ZXLCALSZXD |
11-19-2014, 19:29 | #6 (permalink) |
11-19-2014, 20:11 | #7 (permalink) |
Member: 1603212 Status: Offline Thanks Meter: 26 | Welcome to Octoplus/Octopus Box LG Software version 1.7.5.7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM32 Selected model: MS659 Reading info...OK Mode: Emergency Model ID: BS/MS659/003740 SW version: LGMS659AT-02-V10b-310-260-JUN-13-2013+0 Product ID: SM01S130712010375 IMEI: 013687-00-080486-3 Opening "LGMS659AT-01-V10b-310-260-JUN-13-2013+0.oct"...OK Initializing flash...OK Writing PrimaryGPT...Failed! Error code: ZXLCALSZXD runs a little over 50% then follows falls |
11-19-2014, 20:23 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We will continue research and will try to prepare another test Software version. |
03-04-2015, 20:49 | #10 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Colombia
Member: 565739 Status: Offline Thanks Meter: 93 | Same problem Checking data...OK Platform: LG Qualcomm Selected port: COM229 Selected model: P659 Reading info...OK Mode: Emergency Model ID: BS/LGP659/174158 SW version: LGP659AT-01-V10b-310-260-NOV-04-2013+0 Product ID: HD52S130717000522 IMEI: 013657-00-021199-7 Opening "LGP659AT-01-V10b-310-260-NOV-04-2013+0.oct"...OK Initializing flash...OK Testing connection...OK Writing PrimaryGPT...Failed! Error code: ZXLCALSZXD |
03-05-2015, 06:55 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | What is the state of your phone exactly? What is the problem with your devcie? Why do You want to write new firmware? Install the latest Software version, that we have sent You to PM, try to write firmware again and post here the result. |
03-09-2015, 10:32 | #12 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Dhaka,Uttara.Bangaladash
Member: 1625192 Status: Offline Sonork: 100.1657037 Thanks Meter: 256 | Checking data...OK Platform: LG Qualcomm Selected port: COM32 Selected model: MS659 Reading info...OK Mode: Emergency Model ID: BS/MS659/003740 SW version: LGMS659AT-02-V10b-310-260-JUN-13-2013+0 Product ID: HD52S130710001914 IMEI: 013687-00-043453-9 Opening "LGMS659AT-01-V10b-310-260-JUN-13-2013+0.oct"...OK Initializing flash...OK Testing connection...OK Writing PrimaryGPT...Failed! Error code: ZXLCALSZXD Model: MS659 Error |
03-09-2015, 11:32 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | What is the state of your phone exactly? What is the problem with your devcie? Why do You want to write new firmware? Most likely, your device has HW issue. |
