12-16-2014, 21:28 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Lahore
Member: 392149 Status: Offline Thanks Meter: 199 | LG Nexus 5 D821 cant not unlock [Solved] always failed on swithching serial port here logs 12/17/2014 1:03:23 AM > -------------------------------------------------------------------------------- 12/17/2014 1:03:23 AM > Platform: LG Qualcomm 12/17/2014 1:03:23 AM > Selected port: COM9 12/17/2014 1:03:23 AM > Selected model: D821 12/17/2014 1:03:23 AM > Reading info... 12/17/2014 1:03:35 AM > Initializing ADB...12/17/2014 1:03:36 AM > OK 12/17/2014 1:03:36 AM > Waiting for phone...12/17/2014 1:03:38 AM > OK 12/17/2014 1:03:39 AM > Model ID: Nexus 5 12/17/2014 1:03:39 AM > Firmware version: 12/17/2014 1:03:39 AM > Kernel version: 3.4.0-g88fbc66 12/17/2014 1:03:39 AM > Android version: 5.0 12/17/2014 1:03:40 AM > Hardware: ARMv7 12/17/2014 1:03:59 AM > -------------------------------------------------------------------------------- 12/17/2014 1:03:59 AM > Checking data...12/17/2014 1:04:00 AM > OK 12/17/2014 1:04:00 AM > Platform: LG Qualcomm 12/17/2014 1:04:00 AM > Selected port: COM9 12/17/2014 1:04:00 AM > Selected model: D821 12/17/2014 1:04:00 AM > Reading info... 12/17/2014 1:04:07 AM > Initializing ADB...12/17/2014 1:04:08 AM > OK 12/17/2014 1:04:08 AM > Waiting for phone...12/17/2014 1:04:09 AM > OK 12/17/2014 1:04:10 AM > Model ID: Nexus 5 12/17/2014 1:04:10 AM > Firmware version: 12/17/2014 1:04:10 AM > Kernel version: 3.4.0-g88fbc66 12/17/2014 1:04:10 AM > Android version: 5.0 12/17/2014 1:04:11 AM > Hardware: ARMv7 12/17/2014 1:04:11 AM > After perform Repair IMEI operation, 3G/4G network will be unavailable! 12/17/2014 1:04:15 AM > Initializing ADB...12/17/2014 1:04:16 AM > OK 12/17/2014 1:04:16 AM > Waiting for phone...12/17/2014 1:04:18 AM > OK 12/17/2014 1:04:18 AM > Switching to Fastboot mode...12/17/2014 1:04:31 AM > OK 12/17/2014 1:04:31 AM > Unlocking Bootloader... 12/17/2014 1:04:31 AM > Bootloader is unlocked. 12/17/2014 1:04:31 AM > Writing Bootloader...12/17/2014 1:04:32 AM > OK 12/17/2014 1:04:32 AM > Please, wait while the phone will turn on and press "Ok" button. 12/17/2014 1:06:08 AM > Trying to enable Diagnostics ports... 12/17/2014 1:06:08 AM > Initializing ADB...12/17/2014 1:06:09 AM > OK 12/17/2014 1:06:09 AM > Waiting for phone...12/17/2014 1:06:09 AM > OK 12/17/2014 1:06:09 AM > Checking root access... 12/17/2014 1:06:10 AM > Phone is already rooted. 12/17/2014 1:06:12 AM > Diagnostics ports are enbled! 12/17/2014 1:06:12 AM > Switching to Serial Port... 12/17/2014 1:06:34 AM > Failed! what can i do ????????? Last edited by Octopus box; 12-20-2014 at 12:09. |
12-16-2014, 21:37 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Your phone has Android 5.0 and currently we research the phone, in order to adapt solutions for correct work with this new version of OS. As an option, You can install "LG United Mobile Driver v 3.10.1" and then try to perform "Unlock" operation. |
12-16-2014, 21:40 | #3 (permalink) | |
Member: 392149 Status: Offline Thanks Meter: 199 | Quote:
12-16-2014, 21:50 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please look here: http://forum.gsmhosting.com/vbb/f799/lg-d820-1892749/ |
12-16-2014, 22:33 | #5 (permalink) | |
12-17-2014, 07:41 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | "Write Firmware" is currently not supported for LG D821. On your own risk You can try to re-flash the phone by using "Nexus 5 Root Software" from the Support Area, folder "LG/FOR UNLOCK AND REPAIR/", but it is not recommended to downgrade phone's firmware version. |
12-17-2014, 14:14 | #7 (permalink) |
Freak Poster Join Date: Apr 2014 Location: perú Age: 28
Member: 2169302 Status: Offline Thanks Meter: 51 | same problem downgrade of 5.0 to 4.4 and nothing Platform: LG Qualcomm Selected port: Selected model: D821 Reading info...Failed! Port busyFailed! Could not detect mode! usb debugging is on |
12-17-2014, 14:47 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
1. Re-install drivers (http://octopusbox.com/files/drivers/...dADBDriver.exe,, https://mega.co.nz/#!OlxHUKzC!j5qLEU..._sS4v0fK02kQUg). 2. Disconnect all other devices from PC, turn on "USB Debugging" Mode in the phone. 3. Reboot the PC, re-start the phone and try to connect the device again. | |
12-17-2014, 15:41 | #11 (permalink) |
Member: 2169302 Status: Offline Thanks Meter: 51 | Same problem The sofware ask for a port But the phone only generate mtp and adb but none of at port or modem Last edited by Octopus box; 12-17-2014 at 15:55. |
12-17-2014, 15:55 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Contact us right now to Skype or ICQ, we will look remotely, where can be the problem with your phone. Our contacts You can find in our profile. |
12-18-2014, 08:06 | #14 (permalink) | |
here u go http://forum.gsmhosting.com/vbb/f799...-done-1889988/ | |
12-18-2014, 13:54 | #15 (permalink) | |
here is post LG Nexus 5 lolipop 5.0 unlock pr repair with octopus http://forum.gsmhosting.com/vbb/f799...-done-1889988/ 5.0 is supported with octopus how can i solve swithching serial port | |
