07-17-2015, 20:38 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: izmir
Member: 1210902 Status: Offline Thanks Meter: 231 | Lg nexus4 internal memory problems The device had cfw cynamog on me, but when it comes to internal memory after it looked as 12GB flash in the support section came to this situation and do not fix it. Please can you help. bmp resim yükle resim upload servisleri this fastboot read phone info. |
07-18-2015, 09:52 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please try to reflash the phone with different firmwares from the Support Area. Make Factory Data Reset via phone's menu after each "Write Firmware" operation and check whether problem remains. |
07-18-2015, 16:54 | #3 (permalink) |
Member: 1210902 Status: Offline Thanks Meter: 231 | sir, all support software has been tested in full section software has been tested with all stock has a factory reset wipe results were negative I wonder if I could re-boot install and delete Medusa JTAG if written using the full dump. |
