Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 06-24-2012, 02:09   #1 (permalink)
Member: 1473177
Exclamation LG-P350 Writing AMSS...Failed!
Platform: LG Qualcomm
Selected port: COM8
Selected model: P350
Reading info...OK
Mode: Emergency
Model ID: BS/P350/7D
Opening "LGP350AT-01-V10d-234-33-FEB-16-2011+0.oct"...OK
Checking partition...OK
Writing AMSS...Failed!????????????
Old 06-25-2012, 05:51   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Hello.
Please perform the next steps:
1. Put the phone into Emergency Mode manually (disconnect the cable, reconnect the battery, press and hold "Vol-" + "Vol+" + "Power ON" keys and connect the cable).
2. Select firmware "LGP350AT-01-V10d-234-33-FEB-16-2011+0".
3. Select (check) "Write boot loaders" option.
4. Press "Write firmware" button.
Note: if there will occurs an error during process of writing firmware, You mandatory should reconnect the battery and put the phone into Emergency Mode manually and repeat the procedure of writing firmware again! Otherwise, phone's boot can be damage!
Please uninstall all BB software, modem dashboard software and PC Suite software.
Also please don't use USB hubs or PCI USB ports, You need to use motherboard USB ports only!
Also please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other
programs or attach new devices to your computer during the flashing! Please, follow these simple precautions to avoid damaging your phone.
read eeprom write eeprom, what do i need? jonthe Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 12-08-2010 05:24
MCU EEPROM contents: failed phr3ak Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 02-12-2001 14:58
Nokia 5110 v. 5.24 Unlock Failed! Cybertooth Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 02-28-2000 14:35
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-22-1999 00:28
Page generated in 0.19275 seconds with 11 queries
