09-18-2014, 21:44 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Cali Colombia Age: 43
Member: 181405 Status: Offline Thanks Meter: 249 | LG P659h not unlock no repair imei [Solved] but Octopus always auto select P655 And can´t unlock not repair imei Platform: LG Qualcomm Selected port: COM158 Selected model: P659H Reading info...OK Mode: Normal Model ID: P655H10b: ÿd Firmware compiled date: Mar 10 2014 Firmware compiled time: 11:32:34 Firmware released date: Mar 10 2014 Firmware released time: 11:32:34 SW Version: P655H10b Unlocking... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Reading NVM...OK Backup saved to "P655H_" Reading partition...Failed! Last edited by Octopus box; 10-25-2014 at 06:57. |
09-19-2014, 06:29 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. What is your phone model exactly, P659H or P655H? As You can see, your phone is detected by Software as P655H: Quote:
1. Install the latest Software version (http://octoplusbox.com/en/download/software/); 2. Remove SD and SIM cards from the phone, re-start the phone. 3. Enable USB debugging ("Settings" -> "Developer options" -> "USB Debugging"); 4. Connect powered-on phone to PC with Micro USB cable; 5. Select P655H in the list; 6. Install necessary driver; 7. Click "Unlock" button; 8. Follow software instructions (prompts); 9. Post here full Software log. | |
10-17-2014, 21:35 | #3 (permalink) |
Freak Poster Join Date: Jun 2011 Location: colombia
Member: 1603212 Status: Offline Thanks Meter: 26 | hello friends help with this problem repair imei lg p659h I Flashed and still the same error * security repair I will rebuild nvm all failed Checking data...OK Platform: LG Qualcomm Selected port: COM54 Selected model: P655H Reading info...OK Mode: Normal Model ID: P655H10b: ÿd Firmware compiled date: Jan 7 2014 Firmware compiled time: 15:08:11 Firmware released date: Jan 7 2014 Firmware released time: 15:08:11 SW Version: P655H10b IMEI: 352634-06xxxxxx SPC: 000000 Opening "LGP659hAT-00-V10a-SSV-JAN-07-2014+0 (1).oct"...OK Switching to Download mode...OK Initializing flash...OK Reading partition...OK Formating userdata...OK Writing modem...OK Writing sbl1...OK Writing sbl2...OK Writing sbl3...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing cust...OK Writing persist...OK Writing recovery...OK Writing BackupGPT...OK Finalizing...OK Writing firmware done! Checking data...OK Platform: LG Qualcomm Selected port: COM54 Selected model: P655H Reading info...OK Mode: Normal Model ID: P655H10b: ÿd Firmware compiled date: Jan 7 2014 Firmware compiled time: 15:08:11 Firmware released date: Jan 7 2014 Firmware released time: 15:08:11 SW Version: P655H10b IMEI: 352634-06-004780-0 SPC: 000000 Fixing IMEI... New IMEI: 354567-78-098982-8 Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Checking root access... Phone is already rooted. Reading NVM...OK Backup saved to "P655H_352634060047800_17-10-2014_22-31-30.NVM" Reading partition...Failed! |
10-18-2014, 07:19 | #4 (permalink) | |
Btw, what is the state of your device exactly? What is the problem with the phone? | |
10-24-2014, 16:55 | #5 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Colombia
Member: 726741 Status: Offline Thanks Meter: 1,256 | the same mistake with a similar phone Platform: LG Qualcomm Selected port: COM78 Selected model: P655H Reading info...OK Mode: Normal Model ID: P655H10b: ÿd Firmware compiled date: Jan 7 2014 Firmware compiled time: 10:58:21 Firmware released date: Jan 7 2014 Firmware released time: 10:58:21 SW Version: P655H10b IMEI: 358939-05-072113-0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM78 Selected model: P655H Reading info...OK Mode: Normal Model ID: P655H10b: ÿd Firmware compiled date: Jan 7 2014 Firmware compiled time: 10:58:21 Firmware released date: Jan 7 2014 Firmware released time: 10:58:21 SW Version: P655H10b IMEI: 358939-05-072113-0 Unlocking... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Reading NVM...OK Backup saved to "P655H_358939050721130_24-10-2014_10-52-09.NVM" Reading partition...Failed! |
10-24-2014, 17:46 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | @ WILUNLOCK We have prepared and sent You test Software version to PM. Try to perform the operation by using this Software and post here the result. Also, please fully charge phone's battery before and connect the device directly to PC motherboard USB port (don't use any USB hubs or PCI USB extentions cards, this is important). Try to perform the operation on another PC. |
10-24-2014, 21:46 | #7 (permalink) | |
Member: 726741 Status: Offline Thanks Meter: 1,256 | thanks Quote:
thanks mr problem solved | |
