10-03-2015, 10:41 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | lg p705G partition error Welcome to Octoplus/Octopus Box LG Software version 2.0.0 Platform: LG Qualcomm Selected port: COM58 Selected model: P705g Reading info...OK Mode: Normal Model ID: P705g Firmware compiled date: Mar 05 2012 Firmware compiled time: 07:00:00 Firmware released date: Apr 9 2013 Firmware released time: 09:30:56 SW Version: P705g-M7227A-V10c-APR-09-2013-XX IMEI: 352248-05-655250-7 Bluetooth address: 10:68:3F:B2:14:93 Wi-Fi MAC address: E8:92:A4:F8:7D:0D -------------------------------------------------------------------------- -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM60 Selected model: P705g Reading info...OK Mode: Normal Model ID: P705g Firmware compiled date: Mar 05 2012 Firmware compiled time: 07:00:00 Firmware released date: Apr 9 2013 Firmware released time: 09:30:56 SW Version: P705g-M7227A-V10c-APR-09-2013-XX IMEI: 352248-05-655250-7 Bluetooth address: 10:68:3F:B2:14:93 Wi-Fi MAC address: E8:92:A4:F8:7D:0D Opening "LGP705gAT-00-V10c-RGS-CA-MAY-10-2012+0.oct"...OK Switching to Download mode...OK Checking partition...Failed! solution ? |
10-03-2015, 11:41 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Try to do the next: 1. Install the latest Software version (Software). 2. Fully charge phone's battery. 3. Put the phone into Emergency Mode manually (disconnect the cable, reconnect the battery, press and hold "Vol+" + "Power ON" buttons and connect the cable). 4. Connect the phone directly to PC motherboard USB port - this is important! Don't use any USB hubs or PCI USB extention cards! 5. Select firmware file. 6. Select (check) "Write boot loaders" option in Software. 7. Press "Wrtite Firmware" button. 8. Follow the Software instructions. Note: If it is not possible to write firmware or during firmware writing occures error, You need to re-connect the battery and put manualy phone into Emergency Mode. Also note: make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Please, follow these simple precautions to avoid damaging your phone. |
10-08-2015, 18:34 | #3 (permalink) |
Member: 694535 Status: Offline Thanks Meter: 70 | phone enters in emergency mode only by usb cable 910K Welcome to Octoplus/Octopus Box LG Software version 2.0.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM60 Selected model: P705g Reading info...OK Mode: Emergency Model ID: BS/P705g/7D Opening "LGP705gAT-00-V10c-RGS-CA-MAY-10-2012+0.oct"...OK Checking partition...OK Write BootLoaders: Yes Checking BCPL status...OK BCPL status: 1 Unlocking BCPL...OK BCPE status: 0 Writing QCSBL_CFG...OK Writing QCSBL...OK Writing OEMSBL...OK Writing AMSS...Failed! at this step lcd blinks |
10-09-2015, 11:29 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to write different firmwares. Try to reflash the phone with original firmware and flasher. If neither of this suggestions helps - most likely your device has HW problem. |
