01-10-2015, 12:15 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | To Unlock the phone You need to use special LG P999 cable with 910 kOhm resistor inside. Connect the phone as this written in Software manual ("Cable & Options" tab in the Software) and press "Unlock" button. |
01-10-2015, 13:59 | #6 (permalink) |
Freak Poster Join Date: May 2008
Member: 777178 Status: Offline Sonork: khab Thanks Meter: 23 | sir i have the cable lg p999 i try with 910ko or 56ko but always the same.Welcome to Octoplus/Octopus Box LG Software version 1.8.1 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P970 Please, disconnect battery and connect P999 cable (with 910k resistor).Canceled! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P769 Initializing device...OK Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*769#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...Canceled! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P769 Initializing device...OK Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*769#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...Canceled! |
01-10-2015, 14:39 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Do the next: 1. Install following drivers: http://octopusbox.com/files/drivers/GX300_drviver.rar, http://octopusbox.com/files/drivers/...s_OMAP4430.rar, http://octopusbox.com/files/drivers/...3.10.1.exe.zip. 2. Restart PC. 3. Remove SD and SIM cards from the phone; 4. Power phone ON; 5. Select "Modem" connection mode in Software; 6. Press "Connect" button; 7. Connect phone via P990 cable (with 56k resistor) directly to motherboard USB port; 8. Type 3845#*760#; 9. Go to "Port Setting", select "CP Reset" and click "OK". |
01-10-2015, 18:27 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to use different USB ports for connection. Try to use another P990 cables. Try to perform operation on another, clean (with only necessary drivers and Software) PC. |
