07-15-2014, 15:12 | #1 (permalink) |
No Life Poster Join Date: May 2013 Location: In Core Of eMMC
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | Lg P765 how to flash? i have one lg p765 having hang on logo problem need to flash it.. Please guide me step by step.. |
07-15-2014, 15:22 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please read attentively Software manual (press "Help" button in Software) how to write firmware: 1. Power the phone off. 2. Take out SD and SIM cards from the phone. 3. Select "OMAP" connection mode in the Software. 4. Select firmware file. 5. Press "Write firmware" button. 6. Follow software instructions (prompts). Note, to write firmware You should use the special cable LG P999 with 910 kOhm resistor inside. Connect the phone directly to PC motherboard USB port, don't use any USB hubs or USB PCI cards, this is important. |
07-15-2014, 15:30 | #3 (permalink) | |
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | Quote:
07-15-2014, 16:00 | #4 (permalink) |
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | The software is hang on this what should i do now???? -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P765 Opening "LGP765AT-00-V20c-IND-SEP-02-2013+0_AP.oct"...OK Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader...OK Initializing flash...OK Writing psi.fls...OK Writing slb.fls...OK Writing AENEAS_FW.fls...OK Writing L6260_SIC.fls...OK Writing L6260_SIC-CDS.fls...OK Connecting to application CPU...OK Erasing gpt1...OK Writing gpt1...OK Erasing u-boot... u-boot not erased. Trying to skip. Writing u-boot... |
07-15-2014, 16:03 | #5 (permalink) |
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | Now failed!!! Platform: LG Infineon Connection mode: OMAP Selected model: P765 Opening "LGP765AT-00-V20c-IND-SEP-02-2013+0_AP.oct"...OK Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader...OK Initializing flash...OK Writing psi.fls...OK Writing slb.fls...OK Writing AENEAS_FW.fls...OK Writing L6260_SIC.fls...OK Writing L6260_SIC-CDS.fls...OK Connecting to application CPU...OK Erasing gpt1...OK Writing gpt1...OK Erasing u-boot... u-boot not erased. Trying to skip. Writing u-boot...Failed! |
07-15-2014, 16:06 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Software can't erase and write u-boot section. Most likely, device has HW problems (problems with eMMC flash chip). Try to perform the Repair operation and then try to write firmware again. Connect the cable directly to motherboard USB port, don't use any USB hubs or PCI USB cards. Try to connect the device to another motherboard USB ports. Try on another PC. If the problem is the same, this is HW problem. |
07-15-2014, 16:14 | #7 (permalink) | |
-------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P765 Please, select firmware file -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P765 Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Connecting...OK Sending preloader...OK Sending loader...OK Opening "LGP765AT-00-V20c-IND-SEP-02-2013+0_AP.oct"...OK Initializing device...OK Writing Firmware... Connecting to application CPU...OK Erasing gpt1... gpt1 not erased. Trying to skip. Writing gpt1...Failed! | |
02-26-2016, 18:01 | #9 (permalink) |
Freak Poster Join Date: Nov 2013
Member: 2069837 Status: Offline Thanks Meter: 17 | Welcome to Octoplus/Octopus Box LG Software version 2.1.9 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: OMAP Selected model: P765 Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Connecting...OK Sending preloader...OK Sending loader...OK Opening "LGP765AT-00-V20c-IND-SEP-02-2013+0_AP.oct"...OK Initializing device...OK Writing Firmware... Connecting to application CPU...OK Erasing gpt1...OK Writing gpt1...OK Erasing u-boot... u-boot not erased. Trying to skip. Writing u-boot...Failed! help me |
02-26-2016, 18:36 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to reflash the phone with original firmware and flashing tool. If problem with flashing will remain - most likely your phone has HW problem. |
