09-06-2014, 02:52 | #1 (permalink) |
Freak Poster Join Date: May 2010 Location: Philippines Age: 36
Member: 1297094 Status: Offline Thanks Meter: 7 | LG P768e strange problem [Solved] Last edited by Octopus box; 02-10-2015 at 07:17. |
02-04-2015, 12:25 | #6 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | i hve same problem any help i hve cable 56 res but cant connect Welcome to Octoplus/Octopus Box LG Software version 1.8.3 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P768 Initializing device...OK Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*768#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...Canceled! |
02-04-2015, 12:27 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If after of performing Repair procedure, it is impossible to write firmware, currently no solution for such devices. |
02-04-2015, 13:27 | #8 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Barcelona
Member: 206476 Status: Offline Thanks Meter: 459 | hola Quote:
Welcome to Octoplus/Octopus Box LG Software version 1.7.7 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P760 Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Connecting...OK Sending preloader...OK Sending loader...OK Opening "LGP760AT-00-V20c-EUR-XXX-MAR-25-2013+0_AP.oct"...OK Initializing device...OK Writing Firmware... Connecting to application CPU...OK Erasing gpt1...OK Writing gpt1...OK Erasing u-boot... u-boot not erased. Trying to skip. Writing u-boot...Failed! give me solution or remove this phone from the liste of full supported wbr | |
02-04-2015, 13:36 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Not all devices can be repaired. If after of performing Repair procedure, it is impossible to write firmware, currently no solution for such devices. Also, use the latest Software versin only. |
02-04-2015, 13:47 | #10 (permalink) |
Member: 206476 Status: Offline Thanks Meter: 459 | i use old soft and new with fresh Os on xp and 7 windows is mismo all the times before i dont ask because set recived dead but i have alive phone and he dead // is realy strange i read all your replay on gsmforum if u have any new adjustment u welcome wbr |
02-05-2015, 12:08 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To connect the phone, do the next: 1. Power the phone on. 2. Select "Modem" options in the Software. 3. Press "Connect" button in the Software. 4. Connect the phone to PC directly to motherboard USB port via LG P990 cable with 56k resistor inside. 5. Type 3845#*760#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK". Also write here what the device appears exactly in PC Device Manager, after You perform these steps. |
02-05-2015, 13:48 | #15 (permalink) | |
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
