04-27-2016, 23:02 | #1 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2521399 Status: Offline Thanks Meter: 2 | Lg P769 Cant Connect[Solved] I have done this 100 times, rebooted the phone with the setting, tried a normal USB cable, a 56k resistor, a 180k resistor, a 910k resistor, and I have installed perhaps 6 different sets of drivers, and I have tried it on 2 different computers (One running windows 10 one running windows 7). Nothing works. It simply will not connect. There are 2 things i notice out of the ordinary. One is the phone doesnt read the battery level correct. One second i will unplug it and itll say 100% and 5 minutes later i will unplug it again and itll flash the below 5% warning. Another is that when the phone is plugged in it disconnects and reconnects (judging by the sound the computer makes) several times before it settles in and the computer accepts the drivers. However, it still is not read by the octopus software. Any suggestions? I am pretty sure the cable is good, as I have recently used it without problem. Would reflashing the phone help? Or are there any other troubleshooting steps i can take? Android version: 4.1.2 Baseband: L6260_MODEM_SIC_01.1305.00 Kernel: 3.0.31 Compilation: JZ054K SW Version: P76920h |
04-28-2016, 00:01 | #2 (permalink) |
Member: 2521399 Status: Offline Thanks Meter: 2 | Okay nevermind i got it working. I used the drivers from this thread: http://forum.gsmhosting.com/vbb/f799...-done-1937529/ I was not able to get it to work, even with those drivers, on the windows 7 pc but it went through on the windows 10 pc. |
