08-06-2014, 00:27 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 330758 Status: Offline Thanks Meter: 12 | Lg p769 repair boot problem [Solved] Platform: LG Infineon Connection mode: OMAP Selected model: P769 Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Connecting...OK Sending preloader...OK Sending loader...OK Opening "LGP769AT-01-V20h-310-260-AUG-14-2013+0_AP.oct"...OK Initializing device...OK Writing Firmware... Connecting to application CPU...Failed! Last edited by Octopus box; 09-13-2014 at 07:06. |
08-06-2014, 06:23 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Connect the device directly to PC motherboard USB port, don't use any USB hubs or PCI USB extention cards, this is important. Try to connect the device to other motherboard USB ports. Try to perform the operation on another PC. If the problem is the same - check phone's HW. Also note, You should use the special LG P999 cable with 910 kOhm resistor inside, not the standart Micro USB cable: Quote:
09-12-2014, 20:15 | #3 (permalink) |
Freak Poster Join Date: Jun 2010 Location: MEXICO
Member: 1318721 Status: Offline Thanks Meter: 166 | its correct which mentions sopporter tks Platform: LG Infineon Connection mode: OMAP Selected model: P769 Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Connecting...OK Sending preloader...OK Sending loader...OK Opening "LGP769AT-01-V21b-302-490-APR-17-2013+0_AP.oct"...OK Initializing device...OK Writing Firmware... Connecting to application CPU...OK Erasing gpt1...OK Writing gpt1...OK Erasing u-boot...OK Writing u-boot...OK Erasing boot...OK Writing boot...OK Erasing recovery...OK Writing recovery...OK Erasing misc...OK Writing misc...OK Erasing reserved...OK Writing reserved...OK Erasing system...OK Writing system...OK Repairing boot done. Please, write any firmware from support. |
