03-13-2014, 08:39 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 621334 Status: Offline Thanks Meter: 38 | Lg-p880 imei null [Solved] Welcome to Octoplus/Octopus Box LG Software version 1.4.8 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P880 Initializing device...OK Please, power phone ON, connect P999 cable (with 910k resistor), type 3845#*880#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...Failed! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P880 Initializing device...OK Please, power phone ON, connect P999 cable (with 910k resistor), type 3845#*880#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...OK Reading info...Failed! Certificate load error Disconnected. -------------------------------------------------------------------------------- PLEASE HELP ,, THANKS. Last edited by Octopus box; 03-26-2015 at 14:55. |
03-13-2014, 08:45 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Your device doesn't accept of certificates to work with flash chip. This can be HW problem. Try also to re-flash the phone. |
03-21-2014, 18:43 | #3 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 356508 Status: Offline Thanks Meter: 132 | same i have the same problem and log.this hapen after bad flash is not posible to flash to.i have this error Welcome to Octoplus/Octopus Box LG Software version 1.4.9 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Tegra Selected model: P880 Opening "LGP880AT-00-V10h-EUR-XXX-NOV-19-2012+0.oct"... Please, connect powered OFF phone with P999 (with 910k resistor) cable and press power button...OK Initializing device...OK Reading info... Model ID: BS/P880/1 SW Version: Sending preloader...OK Sending loader...OK Writing Firmware... Setting options...OK Sending hardware info...Failed! any one know what is problem? THX BR |
03-22-2014, 10:34 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to write other firmwares from the Support Area. Try to write "LGP880AT-00-V10f-EUR-XXX-AUG-17-2012+0" at first and post the result here. |
03-26-2014, 15:11 | #5 (permalink) | |
Member: 356508 Status: Offline Thanks Meter: 132 | hi Quote:
Please, connect powered OFF phone with P999 (with 910k resistor) cable and press power button...OK Initializing device...OK Reading info... Model ID: BS/P880/1 SW Version: Sending preloader...OK Sending loader...OK Writing Firmware... Setting options...OK Sending hardware info...Failed! do you have another solution or flash file? THX BR | |
03-26-2014, 15:38 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We have sent You test Software version to your PM. Try to write firmware by using this Software and post here Software log. |
03-26-2014, 15:53 | #7 (permalink) | |
Member: 356508 Status: Offline Thanks Meter: 132 | thx Quote:
i try 3 flash file from support and everi time i have the same resultat Welcome to Octoplus/Octopus Box LG Software version 1.5.0.1 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Tegra Selected model: P880 Opening "LGP880AT-00-V10f-EUR-XXX-AUG-17-2012+0.oct"... Please, connect powered OFF phone with P999 (with 910k resistor) cable and press power button...OK Initializing device...OK Reading info... Model ID: BS/P880/1 SW Version: Sending preloader...OK Sending loader...OK Writing Firmware... Setting options...OK Sending psi.fls...Failed! Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Tegra Selected model: P880 Opening "LGP880AT-00-V10b-CIS-XXX-AUG-27-2012+0.oct"... Please, connect powered OFF phone with P999 (with 910k resistor) cable and press power button...OK Initializing device...OK Reading info... Model ID: BS/P880/1 SW Version: Sending preloader...OK Sending loader...OK Writing Firmware... Setting options...OK Sending psi.fls...Failed! Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P880 Initializing device...OK Please, power phone ON, connect P999 cable (with 910k resistor), type 3845#*880#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...OK Reading info...Failed! Certificate load error Unlocking... Reading EEPROM... Certificate load error Failed! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P880 Initializing device...OK Please, power phone ON, connect P999 cable (with 910k resistor), type 3845#*880#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...OK Reading info...Failed! Certificate load error Creating EEPROM backup...Failed! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P880 Initializing device...OK Please, power phone ON, connect P999 cable (with 910k resistor), type 3845#*880#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...OK Reading info...Failed! Certificate load error Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P880 Initializing device...OK Please, power phone ON, connect P999 cable (with 910k resistor), type 3845#*880#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...OK Reading info...Failed! Certificate load error Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P880 Initializing device...OK Please, power phone ON, connect P999 cable (with 910k resistor), type 3845#*880#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...OK Reading info...Failed! Certificate load error Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P880 Initializing device...OK Please, power phone ON, connect P999 cable (with 910k resistor), type 3845#*880#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...OK Reading info...Failed! Certificate load error Unlocking... Reading EEPROM... Certificate load error Failed! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Tegra Selected model: P880 Opening "LGP880AT-00-V10h-EUR-XXX-NOV-19-2012+0.oct"... Please, connect powered OFF phone with P999 (with 910k resistor) cable and press power button...OK Initializing device...OK Reading info... Model ID: BS/P880/1 SW Version: Sending preloader...Failed! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Tegra Selected model: P880 Opening "LGP880AT-00-V10h-EUR-XXX-NOV-19-2012+0.oct"... Please, connect powered OFF phone with P999 (with 910k resistor) cable and press power button...OK Initializing device...OK Reading info... Model ID: BS/P880/1 SW Version: Sending preloader...OK Sending loader...OK Writing Firmware... Setting options...OK Sending psi.fls...Failed! Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Tegra Selected model: P880 Opening "LGP880AT-00-V10h-EUR-XXX-NOV-19-2012+0.oct"... Please, connect powered OFF phone with P999 (with 910k resistor) cable and press power button...OK Initializing device...OK Reading info... Model ID: BS/P880/1 SW Version: Sending preloader...OK Sending loader...OK Writing Firmware... Setting options...OK Sending psi.fls...Failed! Disconnected. | |
03-26-2014, 16:07 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Your device doesn't accept of certificates to work with flash chip. Currently no solution for such problem. Most likely, this is HW problem. |
05-23-2014, 06:16 | #10 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | @ vickcar13 Hello. Quote:
05-23-2014, 06:40 | #11 (permalink) |
Freak Poster Join Date: Sep 2011 Location: venezuela Age: 37
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | Welcome to Octoplus/Octopus Box LG Software version 1.5.6 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P880 Initializing device...OK Please, power phone ON, connect P999 cable (with 910k resistor), type 3845#*880#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...OK Reading info...Failed! Certificate load error cant read or flash the phone! |
05-23-2014, 07:29 | #12 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | As I have said above, Your device doesn't accept of certificates to work with flash chip: Quote:
03-26-2015, 14:52 | #13 (permalink) | |
No Life Poster Join Date: May 2003 Location: King of Nokia Age: 47
Member: 28531 Status: Offline Thanks Meter: 90 | Quote:
Remove SD and SIM cards from the phone; Install necessary drivers; Power phone ON; Select "Modem" connection mode; Press "Connect" button; Connect phone with P999 cable 910k directly to motherboard USB port; "C:\Program Files\Octoplus\Octoplus_LG\LOG\26-03-2015_15-34-37.log" created. 26.03.2015 15:34:43 > Welcome to Octoplus/Octopus Box LG Software version 1.8.9 26.03.2015 15:34:50 > -------------------------------------------------------------------------------- 26.03.2015 15:34:50 > Platform: LG Infineon 26.03.2015 15:34:50 > Connection mode: Tegra 26.03.2015 15:34:50 > Selected model: P880 26.03.2015 15:34:51 > Opening "LGP880AT-00-V20c-AME-APR-18-2013+0.oct"... 26.03.2015 15:34:51 > Please, connect powered OFF phone with P999 (with 910k resistor) cable and press power button...26.03.2015 15:35:00 > OK 26.03.2015 15:35:00 > Initializing device...26.03.2015 15:35:01 > OK 26.03.2015 15:35:01 > Reading info... 26.03.2015 15:35:01 > Model ID: BS/P880/1 26.03.2015 15:35:01 > SW Version: LGP880AT-00-V20d-AME-XXX-NOV-23-2013+0 26.03.2015 15:35:01 > Sending preloader...26.03.2015 15:35:05 > OK 26.03.2015 15:35:05 > Sending loader...26.03.2015 15:35:19 > OK 26.03.2015 15:35:19 > Writing Firmware... 26.03.2015 15:35:19 > Setting options...26.03.2015 15:35:19 > OK 26.03.2015 15:35:19 > Sending hardware info...26.03.2015 15:35:20 > OK 26.03.2015 15:35:20 > Sending psi.fls... 26.03.2015 15:35:20 > Sending Security start 26.03.2015 15:35:21 > Sending address 26.03.2015 15:35:21 > Sending EraseCheck 26.03.2015 15:35:21 > Sending SetAddress 26.03.2015 15:35:21 > Sending.... 26.03.2015 15:35:22 > Sending Security End26.03.2015 15:35:23 > OK 26.03.2015 15:35:23 > Sending slb.fls... 26.03.2015 15:35:23 > Sending Security start 26.03.2015 15:35:23 > Sending address 26.03.2015 15:35:24 > Sending EraseCheck 26.03.2015 15:35:25 > Sending SetAddress 26.03.2015 15:35:25 > Sending.... 26.03.2015 15:35:29 > Sending Security End26.03.2015 15:35:30 > OK 26.03.2015 15:35:31 > Sending L6260_SIC-CDS.fls... 26.03.2015 15:35:31 > Sending Security start 26.03.2015 15:35:31 > Sending address 26.03.2015 15:35:31 > Sending EraseCheck 26.03.2015 15:35:31 > Sending SetAddress 26.03.2015 15:35:32 > Sending.... 26.03.2015 15:35:49 > Sending Security End26.03.2015 15:35:51 > OK 26.03.2015 15:35:51 > Sending AENEAS_FW.fls... 26.03.2015 15:35:51 > Sending Security start 26.03.2015 15:35:51 > Sending address 26.03.2015 15:35:51 > Sending EraseCheck 26.03.2015 15:35:51 > Sending SetAddress 26.03.2015 15:35:51 > Sending.... 26.03.2015 15:36:01 > Sending Security End26.03.2015 15:36:02 > OK 26.03.2015 15:36:02 > Sending L6260_SIC.fls... 26.03.2015 15:36:02 > Sending Security start 26.03.2015 15:36:02 > Sending address 26.03.2015 15:36:02 > Sending EraseCheck 26.03.2015 15:36:02 > Sending SetAddress 26.03.2015 15:36:03 > Sending.... 26.03.2015 15:39:21 > Sending Security End26.03.2015 15:39:23 > OK 26.03.2015 15:39:23 > Reading partition...26.03.2015 15:39:23 > OK 26.03.2015 15:39:23 > Sending EBT...26.03.2015 15:39:25 > OK 26.03.2015 15:39:25 > Sending EKS...26.03.2015 15:39:28 > OK 26.03.2015 15:39:28 > Sending SOS...26.03.2015 15:39:32 > OK 26.03.2015 15:39:32 > Sending LNX...26.03.2015 15:39:36 > OK 26.03.2015 15:39:36 > Sending APP...26.03.2015 15:42:29 > OK 26.03.2015 15:42:29 > Formating filesystem...26.03.2015 15:42:31 > OK 26.03.2015 15:42:31 > Finalizing...26.03.2015 15:42:31 > OK 26.03.2015 15:42:31 > Writing firmware done! 26.03.2015 15:42:31 > Rebooting phone... 26.03.2015 15:42:31 > Disconnected. factory reset repair eeprom unlock rewrite imei unlock factory reset write frimware again phone work imei normaly | |
