09-02-2014, 18:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | lg p920 flash failed Platform: LG Infineon Connection mode: OMAP Selected model: P920 Opening "LGP920AT-00-V10b-EUR-XXX-JUN-16-2011+0_AP.oct"...OK Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...Failed! Welcome to Octoplus/Octopus Box LG Software version 1.6.7 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P920 Opening "LGP920AT-00-V30a-EUR-APR-04-2013+0_AP.oct"...OK Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...Failed! plz ist possible to solve this problem? |
09-02-2014, 18:57 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What cable do You use exactly? You should use the special LG P999 cable with 910k resistor inside. Connect the device directly to PC motherboard USB port, don't use any USB hubs or PCI USB extention cards, this is important. Try to perform the operation on another PC. If the problem is the same - most likely, this is HW problem. |
