07-09-2014, 21:14 | #1 (permalink) |
Freak Poster Join Date: Nov 2013
Member: 2064519 Status: Offline Thanks Meter: 83 | LG P920 flashing or reapir imei problem i wanna to repair imei p920. i do instruction box but not connect. even not do flash and give error i try with 3 pc installed all driver lg usb and omap driver, installed lastet software box version..... but not solved Platform: LG Infineon Connection mode: OMAP Selected model: P920 Opening "LGP920AT-00-V30a-EUR-APR-04-2013+0_AP.oct"...OK Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...Failed! |
07-10-2014, 06:26 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | What cable do You use exactly? You should use the special LG P999 cable with 910k resistor inside. Connect the device directly to PC motherboard USB port, don't use any USB hubs or PCI USB extention cards, this is important. Try to perform the operation on another PC. If the problem is the same - most likely, this is HW problem. |
