07-03-2014, 20:26 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Here Age: 47
Member: 175183 Status: Offline Sonork: 0 Thanks Meter: 120 | LG P920h cant change option in service menu I try to repair null imei in LG P920h. I use P990 cable with 56k, in usb port direct without hubs. When i enter in service menu cant change Port Setting to CP Image download, always back to "CP USB" Option. Check video. Any help to connect phone? http://*********/f-0F9ExulNs Last edited by gsm_unlock2; 07-03-2014 at 20:33. |
09-24-2014, 18:42 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @hfreire: In order to connect P920H You need to do the next: 1. Remove SD and SIM cards from the phone; 2. Install GX300 driver; 3. Power phone ON; 4. Select "Modem" connection mode; 5. Press "Connect" button; 6. Connect phone with P990 cable directly to motherboard USB port; 7. Type 3845#*920#; 8. Go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK". |
09-24-2014, 19:23 | #7 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Uruguay
Member: 1459662 Status: Offline Thanks Meter: 152 | Quote:
i need downgrade? now is 4.0.4 All drivers is installed, a few days i try with P769 and no problem, unlock and imei very easy. | |
