02-11-2017, 17:34 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Bangladesh
Member: 881225 Status: Offline Sonork: 100.1678282 Thanks Meter: 80 | lg p990 dead problam -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: Tegra Selected model: P990 Opening "LGP990AT-01-V20s-218-90-MAY-21-2012+0_AP.oct"...OK Please, disconnect cable, reconnect battery, press and hold "Vol+"+"Vol-" and connect Micro USB cable... Initializing device...OK Sending loader...OK Creating Boot Config Table...OK Creating Partition Table...OK Creating Fastboot...OK Creating Master Boot Record...OK Creating System...OK Creating CAC...OK Creating Misc...OK Creating Extended Boot Record 1...OK Creating Linux kernel...OK Creating Extended Boot Record 2...OK Creating Digital Rights Management...OK Creating Extended Boot Record 3...OK Creating Recovery...OK Creating Extended Boot Record 4...OK Creating User data A...OK Creating Extended Boot Record 5...OK Creating User data B...OK Formating Boot Config Table...OK Formating Partition Table...OK Formating Fastboot...OK Formating Master Boot Record...OK Formating System...OK Formating CAC...OK Formating Misc...OK Formating Extended Boot Record 1...OK Formating Linux kernel...OK Formating Extended Boot Record 2...OK Formating Digital Rights Management...OK Formating Extended Boot Record 3...OK Formating Recovery...OK Formating Extended Boot Record 4...OK Formating User data A...OK Formating Extended Boot Record 5...OK Formating User data B...OK Writing Fastboot...OK Writing Linux kernel...OK Writing Recovery...OK Finalizing...Failed! Disconnected. Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: Tegra Selected model: P990 Opening "LGP990AT-01-V20s-218-90-MAY-21-2012+0_AP.oct"... Please, connect powered OFF phone with P999 (with 910k resistor) cable and press power button...Canceled! Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: Tegra Selected model: P990 Opening "LGP990AT-01-V20s-218-90-MAY-21-2012+0_AP.oct"...OK Please, disconnect cable, reconnect battery, press and hold "Vol+"+"Vol-" and connect Micro USB cable... Initializing device...OK Sending loader...OK Creating Boot Config Table...OK Creating Partition Table...OK Creating Fastboot...OK Creating Master Boot Record...OK Creating System...OK Creating CAC...OK Creating Misc...OK Creating Extended Boot Record 1...OK Creating Linux kernel...OK Creating Extended Boot Record 2...OK Creating Digital Rights Management...OK Creating Extended Boot Record 3...OK Creating Recovery...OK Creating Extended Boot Record 4...OK Creating User data A...OK Creating Extended Boot Record 5...OK Creating User data B...OK Formating Boot Config Table...OK Formating Partition Table...OK Formating Fastboot...OK Formating Master Boot Record...OK Formating System...OK Formating CAC...OK Formating Misc...OK Formating Extended Boot Record 1...OK Formating Linux kernel...OK Formating Extended Boot Record 2...OK Formating Digital Rights Management...OK Formating Extended Boot Record 3...OK Formating Recovery...OK Formating Extended Boot Record 4...OK Formating User data A...OK Formating Extended Boot Record 5...OK Formating User data B...OK Writing Fastboot...OK Writing Linux kernel...OK Writing Recovery...OK Finalizing...Failed! Disconnected. Performed by 2.5.8 Software version. help plz |
02-13-2017, 09:29 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Try to make "Repair" using different firmwares. Try to use V30 firmware version. Connect the phone directly to PC motherboard USB port, don't use any USB hubs or PCI USB extention cards, this is important. After repairing (even if "Finalizing...Failed!") You should re-flash the phone using LG P999 cable: Quote:
http://forum.gsmhosting.com/vbb/f799.../#post10775176, http://forum.gsmhosting.com/vbb/f799.../#post12319039. | |
