01-11-2015, 12:02 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to re-install drivers, disconnect all other devices from PC, re-boot the PC and try to write firmware again. Connect the phone directly to another motherboard USB port, don't use any USB hubs, this is important. Try to write firmware on another PC. Try to use another cable. |
01-11-2015, 12:58 | #3 (permalink) | |
No Life Poster Join Date: May 2009
Member: 1024748 Status: Offline Thanks Meter: 53 | Quote:
-------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Tegra Selected model: P990 Opening "LGP990AT-00-V30a-EUR-XXX-NOV-30-2012+0_AP.oct"... Please, connect powered OFF phone with P999 (with 910k resistor) cable and press power button...OK Initializing device...OK Writing Firmware... Writing Service data... this is the problem | |
01-11-2015, 14:24 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | What is the problem with the phone exactly? What is the state of the phone? What cable do You use exactly? You should use the special LG P999 with 910k resistor inside, not standart Micro USB cable. Also, install the latest Software version. |
01-11-2015, 14:27 | #5 (permalink) |
Member: 1024748 Status: Offline Thanks Meter: 53 | Installed driver using p999 cable... Customer want to update it .. Phone is complete ok.. Need to update.. I have evereything but i think problem with procedure... I connect phone open with p999 cable... With sw update mode its detect on modem mode with phone open its detect on tegra mode |
01-12-2015, 07:20 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to use another LG P999 cable. Connect the phone directly to another motherboard USB port, don't use any USB hubs. Try to write firmware on another PC. No other way. Also, install the latest Software version (http://octoplusbox.com/en/download/software/), You use very old Software. |
01-12-2015, 07:24 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Do the next: 1. Power the phone OFF. 2. Remove SD and SIM cards from the phone. 3. Connect phone with P999 cable and power it ON. 4. Select "Tegra" option in the Software. 5. Select firmware file. 6. Press "Write Firmware" button. 7. Follow the Software instructions (prompts). |
