12-15-2017, 16:14 | #1 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | LG Q6 7.1.1 Reset FRP 100% done Welcome to Octoplus/Octopus Box LG Software version 2.7.8 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: M700 Reading info... Could not detect mode! Performed by 2.7.8 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM5 Selected model: M700 Reading info... Model ID: LG-M700TV IMEI: 358756-08-041361-5 Android version: 7.1.1 Battery level: 55% SW Version: M70010j Mode: Emergency Initializing flash...OK SW version: LGM700TVAT-00-V10r-724-06-AUG-28-2017-32G+0 Android version: 7.1.1 LAF Version: 1.1 Product ID: BR10S170816000621 IMEI: 358756-08-041361-5 Target operator: GLOBAL Hardware: rev_10 Performed by 2.7.8 Software version. To perform Reset FRP operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint. Performed by 2.7.8 Software version. To perform Reset FRP operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint. Cannot terminate an externally created thread Performed by 2.7.8 Software version. To perform Reset FRP operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint. Found port COM15 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request...OK Reading partitions...OK Searching signatures... Resetting FRP Lock... Rebooting phone... Performed by 2.7.8 Software version. Last edited by Octopus box; 12-15-2017 at 16:24. |
The Following User Says Thank You to bruno santana For This Useful Post: |
12-15-2017, 19:21 | #2 (permalink) |
Junior Member Join Date: Nov 2010 Location: Venezuela
Member: 1444028 Status: Offline Thanks Meter: 7 | Error I get an error, I do not understand what I'm doing wrong, I've done it with both connected and disconnected batteries and the error is the same, it's an M700F 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS-USB QDLoader 9008". 3. Release testpoint. Found port COM20 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Performed by 2.7.8 Software version. |
The Following User Says Thank You to eamu For This Useful Post: |
12-15-2017, 19:43 | #3 (permalink) |
Member: 1444028 Status: Offline Thanks Meter: 7 | FRP Done! Done, I was not releasing the TP after recognizing the PC To perform Reset FRP operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS-USB QDLoader 9008". 3. Release testpoint. Found port COM20 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request...OK Reading partitions...OK Searching signatures... Resetting FRP Lock... Rebooting phone... Performed by 2.7.8 Software version. |
The Following 2 Users Say Thank You to eamu For This Useful Post: |
12-15-2017, 23:49 | #5 (permalink) |
Junior Member Join Date: May 2016 Location: Veracruz Mexico
Member: 2570787 Status: Offline Thanks Meter: 26 | Octopus says to remove the FRP in its last update, but it does not remove it. It is removed, it turns on for a period of time, it restarts itself and asks for a new account. Tested an hour ago with two phones. |
12-16-2017, 00:05 | #6 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | Quote:
Remove frp with Octopus And After phone full states activated developper mode and active OEM LOCK and do full hard reste in setting menu | |
03-18-2018, 15:37 | #11 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Quote:
If You want to reset FRP on M700x, do the following: 1. Attach testpoint as shown on M700 TP, and connect phone with Micro USB cable (donīt use USB hubs!). 2. Check PC Device Manager, a new device should appear "Qualcomm HS-USB QDLoader 9008" or "Unknown Device" if you hadnīt installed a driver. Drivers are in {Installation_Folder}\Driver\QHSUSB. 3. Release testpoint and press "Reset FRP Lock" button at "Android Tools" tab. 4. Follow software instructions (prompts). Please always read Software manual ("Cable & Manual" button) before to perform any operation. Last edited by Octopus box; 03-18-2018 at 15:43. | |
