03-11-2020, 15:43 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dominican Republic Age: 40
Member: 605730 Status: Offline Sonork: 100.1605690 Thanks Meter: 70 | lg q720gm stylo 5 error flash [Answered] Hardware: rev_10 Opening "Q720QM10d_00_NAO_US_OP_1017.kdz"...OK Firmware version: Q720QM10d Firmware model: LM-Q720 Firmware type: 0400 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing 1/143 gpt_main0.bin_0...OK Writing 2/143 NON-HLOS.bin_16384...OK Writing 3/143 NON-HLOS.bin_196608...OK Writing 4/143 mdtp.img_376832...Failed! Error code: ZXLCALSZXC Performed by 3.0.0 Software version. |
03-11-2020, 16:03 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please, download and install the latest test Software version from the Support Area, after repeat operation again |
03-11-2020, 16:23 | #3 (permalink) | |
Member: 605730 Status: Offline Sonork: 100.1605690 Thanks Meter: 70 | Quote:
Opening "Q720QM10d_00_NAO_US_OP_1017.kdz"...OK Firmware version: Q720QM10d Firmware model: LM-Q720 Firmware type: 0400 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Selecting firmware partitions...OK Selected default partitions! Sending signature...OK Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/143 gpt_main0.bin_0... Performed by 3.0.0.03 Software version. | |
03-11-2020, 16:33 | #5 (permalink) |
Member: 605730 Status: Offline Sonork: 100.1605690 Thanks Meter: 70 | Welcome to Octoplus/Octopus Box LG Software version 3.0.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM382 Selected model: Q720L Reading info... Model ID: LM-Q720PS IMEI: 356095-10-7 Android version: 9 Battery level: 65% Mode: Emergency Initializing flash...OK Platform: msm8953 SW version: LMQ720PSAT-00-V13a-310-120-OCT-29-2019-ARB00+3 Android version: 9 LAF Version: 1.1 Product ID: CW83S190827001709 IMEI: 356095- Target operator: LAO Hardware: rev_10 Opening "Q720QM10d_00_NAO_US_OP_1017.kdz"...OK Firmware version: Q720QM10d Firmware model: LM-Q720 Firmware type: 0400 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing 1/143 gpt_main0.bin_0...OK Writing 2/143 NON-HLOS.bin_16384...OK Writing 3/143 NON-HLOS.bin_196608...OK Writing 4/143 mdtp.img_376832...Failed! Error code: ZXLCALSZXC Performed by 3.0.0 Software version. |
03-11-2020, 17:07 | #6 (permalink) | |||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
