02-06-2018, 19:00 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: tropical island
Member: 1568769 Status: Offline Sonork: 161.1167 Thanks Meter: 208 | LG SP200 7.1.2 unlock question [Answered] Last edited by Octopus box; 02-07-2018 at 09:31. |
07-20-2018, 14:59 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We have sent You test Software version to PM. Also we have uploaded the special firmware "SP20010b_to_X210ULMA10d_for_unlock.oct" for unlock for this device model into the Support Area into folder "LG/FOR UNLOCK AND REPAIR". Do the following: 1. Install the test Software version. 2. Connect your device and read EEPROM backup ("Read EEPROM" button). 3. Write the special firmware "SP20010b_to_X210ULMA10d_for_unlock.oct" from the Support Area. 4. Reboot the phone and write EERPOM backup ("Write EEPROM" button). 5. Insert SIM card and check network. Also check IMEI. 6. Post here full Software log and say the result. |
07-20-2018, 20:18 | #8 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2560297 Status: Offline Thanks Meter: 0 | Hi, I have an lg sp200 with the software version sp20011b with the security of 1 frame of 2018. My question is do you think it is in qloader because it is going to be a downgrade? |
07-21-2018, 10:16 | #9 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
Please put the device into Download (Emergency) Mode manually, perform "Read info" operation and post here full Software log with this info, we will check it. | |
07-22-2018, 22:31 | #10 (permalink) | |
Member: 2560297 Status: Offline Thanks Meter: 0 | Quote:
Welcome to Octoplus/Octopus Box LG Software version 2.8.7 -------------------------------------------------------------------------------- Platform: LG MTK Selected port: COM6 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM60 Port is not active! Performed by 2.8.7 Software version. -------------------------------------------------------------------------------- Platform: LG MTK Selected port: COM6 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM60 Mode: Emergency Initializing flash...OK Model ID: LG-SP200 Platform: mt6750 SW version: SP20011b_00 LAF Version: 1.1 Product ID: CT66S180117005790 IMEI: Target operator: SPR Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 351980-xx-xxxxxx-x MEID: 351980-xx-xxxxxx Bluetooth address: 00:3D:E8:4D4:58 Wi-Fi MAC address: 00:3D:E8:CD:02:E3 SPC: 787040 -------------------------------------------------------------------------------- Performed by 2.8.7 Software version. | |
07-23-2018, 08:11 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You can try to write (downgrade) firmware at your own risk, most likely, there is shouldn't be problem with downgrading, but always exist small risk do damage the device. |
07-23-2018, 16:42 | #12 (permalink) | |
if you accept I will tell you what happened. | |
07-24-2018, 22:27 | #13 (permalink) |
Junior Member Join Date: Oct 2017
Member: 2768474 Status: Offline Thanks Meter: 1 | someone could pass me the stock SP20011b_00 because when trying to degrade the phone to brickedo try to degrade it with the stock stored on the octoplus server and I was brickeado help please |
07-25-2018, 17:09 | #14 (permalink) | |
Freak Poster Join Date: Jul 2017
Member: 2738165 Status: Offline Thanks Meter: 23 | Quote:
07-25-2018, 17:34 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You can try to use the lalest Software version. But note, that writing the special firmware may lead to device damage, so do this at your own risk. If will try, please fully charge phone's battery before. Also we recommend to perform Factorty/Hard Reset before to write the special firmware. |
