12-11-2019, 13:24 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | lg m150 unlock problam [Solved] Checking data...OK Platform: LG Qualcomm Selected port: COM46 Selected model: M150 Reading info... Model ID: LG-M150 IMEI: 354063-08-771312-9 Android version: 7.0 Battery level: 42% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGM150AT-01-V20e-310-410-AUG-11-2017-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CB41S170718004576 IMEI: 354063-08-771312-9 Target operator: ATT Hardware: rev_10 Unlocking... Switching to Normal mode... Found model LGM150AT: ÿh `î at port COM46 Performed by 2.9.5 Software version. |
12-11-2019, 14:23 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Quote:
12-11-2019, 14:45 | #3 (permalink) |
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | 12/11/2019 6:32:48 PM > -------------------------------------------------------------------------------- 12/11/2019 6:32:48 PM > Checking data...12/11/2019 6:32:49 PM > OK 12/11/2019 6:32:49 PM > Platform: LG Qualcomm 12/11/2019 6:32:49 PM > Selected port: COM386 12/11/2019 6:32:49 PM > Selected model: M150 12/11/2019 6:32:49 PM > Reading info... 12/11/2019 6:32:52 PM > Mode: Emergency 12/11/2019 6:32:52 PM > Initializing flash...12/11/2019 6:32:54 PM > OK 12/11/2019 6:32:55 PM > Platform: msm8909 12/11/2019 6:32:55 PM > SW version: 12/11/2019 6:32:55 PM > LGM150AT-01-V20d-310-410-MAY-02-2017-ARB00+0 12/11/2019 6:32:55 PM > Android version: 7.0 12/11/2019 6:32:55 PM > LAF Version: 1.1 12/11/2019 6:32:55 PM > Product ID: CB42S170421007776 12/11/2019 6:32:55 PM > IMEI: 354063-08-289316-5 12/11/2019 6:32:55 PM > Target operator: ATT 12/11/2019 6:32:55 PM > Hardware: rev_10 12/11/2019 6:32:55 PM > Unlocking... 12/11/2019 6:32:55 PM > Switching to Normal mode... 12/11/2019 6:34:16 PM > Trying to enable Diagnostics ports...12/11/2019 6:34:16 PM > Failed! 12/11/2019 6:34:16 PM > Trying to enable Diagnostics ports... 12/11/2019 6:34:16 PM > Initializing ADB...12/11/2019 6:34:17 PM > OK 12/11/2019 6:34:17 PM > Waiting for phone...12/11/2019 6:34:17 PM > OK 12/11/2019 6:34:20 PM > Diagnostics ports are enbled! 12/11/2019 6:34:20 PM > Switching to Serial Port...12/11/2019 6:34:23 PM > Failed! 12/11/2019 6:34:23 PM > Trying to enable Diagnostics ports... 12/11/2019 6:34:23 PM > Checking root access...12/11/2019 6:34:23 PM > Failed! 12/11/2019 6:34:23 PM > Error code: ADB0000001 12/11/2019 6:34:23 PM > Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect USB cable to then phone 4. Press "Ok" button 12/11/2019 6:34:31 PM > Trying to enable Diagnostics ports...12/11/2019 6:34:31 PM > Failed! 12/11/2019 6:34:31 PM > Trying to enable Diagnostics ports... 12/11/2019 6:34:31 PM > Failed! 12/11/2019 6:34:33 PM > Performed by 2.9.7.01 Software version. |
12-11-2019, 14:50 | #4 (permalink) |
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | *#546368#*150# or 3845*#150#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". Welcome to Octoplus/Octopus Box LG Software version 2.9.7.01 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM386 Selected model: M150 Reading info... Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGM150AT-01-V20d-310-410-MAY-02-2017-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CB42S170421007776 IMEI: 354063-08-289316-5 Target operator: ATT Hardware: rev_10 Unlocking... Switching to Normal mode... Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port...Failed! Trying to enable Diagnostics ports... Checking root access... Phone is not rooted. Please, root the phone manually! Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect USB cable to then phone 4. Press "Ok" button Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Failed! Performed by 2.9.7.01 Software version. |
12-11-2019, 14:53 | #5 (permalink) |
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | Welcome to Octoplus/Octopus Box LG Software version 2.9.7.01 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM386 Selected model: M150 Reading info... Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGM150AT-01-V20d-310-410-MAY-02-2017-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CB42S170421007776 IMEI: 354063-08-289316-5 Target operator: ATT Hardware: rev_10 Unlocking... Switching to Normal mode... Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port...Failed! Trying to enable Diagnostics ports... Checking root access... Phone is not rooted. Please, root the phone manually! Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect USB cable to then phone 4. Press "Ok" button Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Failed! Performed by 2.9.7.01 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: M150 Reading info... Could not detect mode! Performed by 2.9.7.01 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM46 Selected model: M150 Reading info...Failed! Port busy Performed by 2.9.7.01 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM386 Selected model: M150 Reading info... Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGM150AT-01-V20d-310-410-MAY-02-2017-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CB42S170421007776 IMEI: 354063-08-289316-5 Target operator: ATT Hardware: rev_10 Fixing IMEI... New IMEI: 355246-47-657676-4 Switching to Normal mode... Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port...Failed! Trying to enable Diagnostics ports... Checking root access... Phone is not rooted. Please, root the phone manually! Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect USB cable to then phone 4. Press "Ok" button Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Failed! Performed by 2.9.7.01 Software version. |
12-11-2019, 15:12 | #6 (permalink) | |
Select "File transfer" mode in "Use USB connection for" window, then press "Always"; Type 277634#*# or *#546368#*150# or 3845*#150#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". | |
12-11-2019, 16:00 | #7 (permalink) |
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | Welcome to Octoplus/Octopus Box LG Software version 2.9.7.01 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: M150 Reading info... Could not detect mode! Performed by 2.9.7.01 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: M150 Reading info... Could not detect mode! Performed by 2.9.7.01 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM12 Selected model: M150 Reading info... Model ID: LG-M150 IMEI: 353712-09-299875-9 Android version: 7.0 Battery level: 98% Mode: Normal Firmware compiled date: Jul 06 2017 Firmware compiled time: 04:00:00 Firmware released date: Aug 11 2017 Firmware released time: 17:20:11 SW Version: MPSS.JO.2.0.c1.2-00020-8909_GEN_PACK- 1.92496.1.104247.1 IMEI: 353712-09-299875-9 Bluetooth address: B4:F1A:32:01:15 Wi-Fi MAC address: B4:F1A:A4:3E:AE SPC: 000000 Unlocking... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.9.7.01 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM12 Selected model: M150 Reading info... Model ID: LG-M150 IMEI: 353712-09-299875-9 Android version: 7.0 Battery level: 98% Mode: Normal Firmware compiled date: Jul 06 2017 Firmware compiled time: 04:00:00 Firmware released date: Aug 11 2017 Firmware released time: 17:20:11 SW Version: MPSS.JO.2.0.c1.2-00020-8909_GEN_PACK- 1.92496.1.104247.1 IMEI: 353712-09-299875-9 Bluetooth address: B4:F1A:32:01:15 Wi-Fi MAC address: B4:F1A:A4:3E:AE SPC: 000000 Unlocking... Initializing ADB...OK Waiting for phone...OK Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "M150_353712092998759_11-12-2019_19-50- 09.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method...OK Reading security area...OK Backup saved to "M150_353712092998759_11-12-2019_19-55- 50.SEC" Writing security area...OK Switching to Normal mode... Found model LGM150AT* ÿh `– at port COM12 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! Rebooting phone... Performed by 2.9.7.01 Software version. tnx team |
The Following User Says Thank You to alimobile279 For This Useful Post: |
