10-23-2018, 05:04 | #38 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Here is test Software version: https://drive.google.com/file/d/1qQh...shotKi7zn/view. Here is the special test firmware for Unlock: https://drive.google.com/file/d/1PFQ...xg2jrMumq/view Do the following at your own risk: 1. Install this test Software version v2.8.9.5. 2. Fully charge phone's battery. 3. Read EEPROM Backup. 4. Select SP200 and write "SP200.._for_unlock" firmware 5. Put the phone into Download (Emergency) Mode AND write EEPROM Backup, this is important! 6. Post here the result. Last edited by Octopus box; 10-24-2018 at 06:01. |
The Following 6 Users Say Thank You to Octopus box For This Useful Post: |
10-23-2018, 18:45 | #39 (permalink) |
Freak Poster Join Date: Mar 2012 Location: the moon
Member: 1740779 Status: Offline Thanks Meter: 143 | No one is posting results which is kind of the point of testing, I know a number of techs who have used this software and software from other sources that leave their phones with problems and no one knows why. Has anyone else had success or failure with this software that got it from here and used it on their phone with out having done anything to it previously? |
10-23-2018, 19:44 | #40 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2229047 Status: Offline Thanks Meter: 0 | I tested with one its unlocked but the imei will have to be repaired it seems also it takes some time to boot and had to do a factory reset. I will try another and post result |
10-23-2018, 19:51 | #41 (permalink) | |
Member: 1740779 Status: Offline Thanks Meter: 143 | Quote:
here is mine before and after 10/20/2018 11:01:07 AM > Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. 10/20/2018 11:01:56 AM > Phone found at port COM12 10/20/2018 11:02:00 AM > Mode: Emergency 10/20/2018 11:02:00 AM > Initializing flash...10/20/2018 11:02:02 AM > OK 10/20/2018 11:02:03 AM > Model ID: LG-SP200 10/20/2018 11:02:03 AM > Platform: mt6750 10/20/2018 11:02:03 AM > Android version: 7.1.2 10/20/2018 11:02:03 AM > SW version: SP20010b_00 10/20/2018 11:02:03 AM > LAF Version: 1.1 10/20/2018 11:02:03 AM > Product ID: CT66S171227000420 10/20/2018 11:02:03 AM > IMEI: 10/20/2018 11:02:03 AM > Target operator: SPR 10/20/2018 11:02:03 AM > Hardware: rev_10 10/20/2018 11:02:03 AM > Battery level: 50% 10/20/2018 11:02:03 AM > Reading partitions...10/20/2018 11:02:03 AM > OK10/20/2018 11:02:04 AM > OK 10/20/2018 11:02:06 AM > Checking security... 10/20/2018 11:02:06 AM > Read 00380000... 10/20/2018 11:02:06 AM > Checking security passed! 10/22/2018 6:28:37 PM > Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. 10/22/2018 6:28:51 PM > Phone found at port COM12 10/22/2018 6:28:55 PM > Mode: Emergency 10/22/2018 6:28:55 PM > Initializing flash...10/22/2018 6:28:57 PM > OK 10/22/2018 6:28:58 PM > Model ID: LM-X210ULMA 10/22/2018 6:28:58 PM > Platform: mt6750 10/22/2018 6:28:58 PM > Android version: 7.1.2 10/22/2018 6:28:58 PM > SW version: LMX210ULMAAT-00-V10d-LAO-COM-MAR-16-2018-ARB00+0 10/22/2018 6:28:58 PM > LAF Version: 1.1 10/22/2018 6:28:58 PM > Product ID: CT66S171227000420 10/22/2018 6:28:58 PM > IMEI: 10/22/2018 6:28:58 PM > Target operator: LAO 10/22/2018 6:28:58 PM > Hardware: rev_10 10/22/2018 6:28:58 PM > Battery level: 50% 10/22/2018 6:28:58 PM > Reading partitions...10/22/2018 6:28:58 PM > OK 10/22/2018 6:29:00 PM > Checking security... 10/22/2018 6:29:00 PM > Read 00800000... 10/22/2018 6:29:00 PM > Checking security passed! | |
10-23-2018, 21:34 | #43 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2267715 Status: Offline Thanks Meter: 2 | help im just flashed the file but now the cellphone touchscreen dosnt work and the image is split https://ibb.co/mT0NrV?fbclid=IwAR3YH...FLe5Nnuit4Zkf4 https://ibb.co/mT0NrV?fbclid=IwAR3YH...FLe5Nnuit4Zkf4 |
10-23-2018, 21:37 | #44 (permalink) | |
10-23-2018, 21:46 | #45 (permalink) |
Member: 2267715 Status: Offline Thanks Meter: 2 | already close and try to reflash.. everythings flash just fine. dont find the first log. heres the last one Welcome to Octoplus/Octopus Box LG Software version 2.8.9.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM171 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: SP20014c_00 LAF Version: 1.1 Product ID: VS02S180918006011 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OKOK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 359634-09-448681-1 MEID: 359634-09-448681 Bluetooth address: 00:57:C1:5A:FE:8B Wi-Fi MAC address: 00:57:C1:FB:9D:9E SPC: 249601 -------------------------------------------------------------------------------- Reading security area...OK Backup saved to "SP200_359634094486811_23-10-2018_12-57-48.EEP" -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "SP20013b_to_X210ULMA10d_for_unlock.oct"...OK Setting options...OK Reading partitions...OKOK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing preloader...OK Writing pgpt...OK Writing lk...OK Writing lk2...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing logo...OK Writing lo_bak_go...OK Writing secro...OK Writing tee1...OK Writing tee2...OK Writing rct...OK Writing factory...OK Writing efuse...OK Writing md1img...OK Writing md1dsp...OK Writing md1arm7...OK Writing md3img...OK Writing system...OK Writing lafbak...OK Writing sgpt...OK Writing ftm...OK Writing cache...OK Writing OP...OK Writing userdata...OK Formating RCT...OK Finalizing...OK Performed by 2.8.9.5 Software version. -------------------------------------------------------------------------------- Platform: LG MTK Selected port: COM170 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM171 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: LMX210ULMAAT-00-V10d-LAO-COM-MAR-16-2018-ARB00+ 0 LAF Version: 1.1 Product ID: 00000000000000000000000000000 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OKOK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 350305-26-000000-1 MEID: 350305-26-000000 Bluetooth address: 00:05:C9:00:00:00 Wi-Fi MAC address: 00:00:00:00:00:00 SPC: 000000 -------------------------------------------------------------------------------- Performed by 2.8.9.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM170 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM171 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: LMX210ULMAAT-00-V10d-LAO-COM-MAR-16-2018-ARB00+ 0 LAF Version: 1.1 Product ID: 00000000000000000000000000000 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OKOK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 350305-26-000000-1 MEID: 350305-26-000000 Bluetooth address: 00:05:C9:00:00:00 Wi-Fi MAC address: 00:00:00:00:00:00 SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Trying third method...OK Opening "SP200_35963409448681_22-10-2018_15-06-32.eep"...OK Writing EEPROM...OK EEPROM succesfully repaired. Performed by 2.8.9.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM170 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM171 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: LMX210ULMAAT-00-V10d-LAO-COM-MAR-16-2018-ARB00+ 0 LAF Version: 1.1 Product ID: VS02S180918006011 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OKOK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 359634-09-448681-1 MEID: 359634-09-448681 Bluetooth address: 00:57:C1:5A:FE:8B Wi-Fi MAC address: 00:57:C1:FB:9D:9E SPC: 249601 -------------------------------------------------------------------------------- Reading security area...OK Backup saved to "SP200_359634094486811_23-10-2018_13-25-09.EEP" -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "SP20013b_to_X210ULMA10d_for_unlock.oct"...OK Setting options...OK Reading partitions...OKOK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing preloader...OK Writing pgpt...OK Writing lk...OK Writing lk2...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing logo...OK Writing lo_bak_go...OK Writing secro...OK Writing tee1...OK Writing tee2...OK Writing rct...OK Writing factory...OK Writing efuse...OK Writing md1img...OK Writing md1dsp...OK Writing md1arm7...OK Writing md3img...OK Writing system...OK Writing lafbak...OK Writing sgpt...OK Writing ftm...OK Writing cache...OK Writing OP...OK Writing userdata...OK Formating RCT...OK Finalizing...OK Performed by 2.8.9.5 Software version. any suggestion? |
The Following User Says Thank You to Lipon625 For This Useful Post: |
