10-26-2018, 09:40 | #62 (permalink) |
Insane Poster Join Date: May 2015 Location: VietNam
Member: 2400933 Status: Offline Thanks Meter: 36 | Hi, Fully charge phone's battery 100% and try to write EEPROM backup again still failed Checking data...OK Platform: LG MTK Selected port: COM56 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM175 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: LAF Version: 1.1 Product ID: IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OKOK Checking security...Failed! -------------------------------------------------------------------------------- IMEI: MEID: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Trying third method...OK Opening "SP200_35198009617748_24-10-2018_21-13-40.eep"...OK Writing EEPROM...Failed! LAF Error: 80000001. Performed by 2.8.9.5 Software version. |
10-26-2018, 10:10 | #63 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Do the next: 1. Run Software. 2. Try to write EEPROM again. 3. Close the Software. 4. Upload somewhere the latest cleated "*.log" file with performed operations from the Software logs folder and post here link, we will research it. |
10-27-2018, 04:03 | #66 (permalink) | |
Freak Poster Join Date: Jul 2009 Location: Dominican Republic Age: 35
Member: 1078865 Status: Offline Sonork: 100.1626549 Thanks Meter: 83 | Not need write eeprom Quote:
Not need write eeprom, write imei and done | |
10-27-2018, 05:11 | #67 (permalink) |
Junior Member Join Date: Mar 2006 Location: Colombia
Member: 247153 Status: Offline Thanks Meter: 8 | Sp200 The phone restarts after flash 1. Install this test Software version v2.8.9.5. (OK done) 2. Fully charge phone's battery. (OK done) 3. Read EEPROM Backup. (OK done) 4. Select SP200 and write "SP200.._for_unlock" firmware (OK done) 5. Put the phone into Download (Emergency) Mode AND write EEPROM Backup, this is important! (OK done) - Hard Reset ok - Imei ok - Signal ok - But the phone restarts constantly... https://www.youtube.com/watch?v=9WxdO9HMpZo |
10-29-2018, 15:22 | #68 (permalink) |
Freak Poster Join Date: May 2016 Location: CUBA Age: 32
Member: 2572618 Status: Offline Sonork: no Thanks Meter: 185 | Hello. Why after Reboot it ASK for Encription Passwor? I do factory Reset and Starts normal, but again after reboot, starts like safe mode... and aks pass BR |
10-29-2018, 17:31 | #71 (permalink) |
Member: 2572618 Status: Offline Sonork: no Thanks Meter: 185 | Somebody knows how to solve this problem? Why after Reboot it ASK for Encription Passwor? I do factory Reset and Starts normal, but again after reboot, starts like safe mode... and aks pass BR |
10-30-2018, 18:02 | #72 (permalink) |
Freak Poster Join Date: Jul 2017
Member: 2738165 Status: Offline Thanks Meter: 23 | LG SP200 says, "invalid battery, shutting down" after flashing EEPROM Welcome to Octoplus/Octopus Box LG Software version 2.8.9.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM38 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: LMX210ULMAAT-00-V10d-LAO-COM-MAR-16-2018-ARB00+ 0 LAF Version: 1.1 Product ID: 00000000000000000000000000000 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OKOK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 3XXXXX-26-000000-1 MEID: 3XXXXX-26-000000 Bluetooth address: 00:05:C9:00:00:00 Wi-Fi MAC address: 00:00:00:00:00:00 SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Trying third method...OK Opening "SP200_XXXXXXXXXXXXXXX_25-10-2018_10-29-04.EEP"...OK Writing EEPROM...OK EEPROM succesfully repaired. Performed by 2.8.9.5 Software version. __________________________________________________ ________ Any probable cause? |
