03-24-2018, 17:11 | #1 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Puerto Rico
Member: 1966203 Status: Offline Thanks Meter: 10 | LG-SP320 FRP Reset question [Solved] -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM10 Selected baudrate: 0 Selected model: M250 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM10 Mode: Emergency Initializing flash...OK Model ID: LG-SP320 SW version: SP32010e_01 LAF Version: 1.1 Product ID: CT68S170922001959 IMEI: 358226-08-XXXXXXX Target operator: SPR Hardware: rev_10 Battery level: 4294967295% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 358226-08-XXXXXXX Bluetooth address: 10:F1:F2:F8:43:07 Wi-Fi MAC address: 10:F1:F2:70:54:61 SPC: 648730 -------------------------------------------------------------------------------- Reset FRP operation for M250 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Writing loader...Failed! LAF Error: 00000000. Reset FRP operation is currently not supported for your phone's firmware. Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- i think the phone have version 7.1.1 Last edited by Octopus box; 07-21-2018 at 08:47. |
03-25-2018, 12:38 | #2 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Tthere is the one of the latest firmware version in your device: Quote:
You can try to downgrade phone firmware at your own risk (downgrade may lead to phone damage) and then do "Reset FRP" operation. Last edited by Octopus box; 04-07-2018 at 09:32. | ||
04-07-2018, 09:34 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Post here (or send us to PM, if You can't post here) full Software log with all of performed operations with the device, we will check. Also please read and always follow these rules: http://forum.gsmhosting.com/vbb/f799...leted-2165821/, http://forum.gsmhosting.com/vbb/f62/...rules-1591101/. |
07-17-2018, 16:19 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please read and always follow these rules: http://forum.gsmhosting.com/vbb/f799...leted-2165821/, http://forum.gsmhosting.com/vbb/f62/...rules-1591101/. |
07-19-2018, 15:45 | #7 (permalink) |
Crazy Poster Join Date: Aug 2008
Member: 848549 Status: Offline Thanks Meter: 9 | the phone shutt off after 30 second and you don't have reset option Welcome to Octoplus/Octopus Box LG Software version 2.8.7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM184 Selected baudrate: 0 Selected model: SP320 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM184 Mode: Emergency Initializing flash...OK Model ID: LG-SP320 Platform: mt6750 SW version: SP32010f_04 LAF Version: 1.1 Product ID: CT67S171025001247 IMEI: 358226-08-171774-5 Target operator: SPR Hardware: rev_10 Battery level: 4294967295% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 358226-08-171774-5 MEID: 358226-08-171774 Bluetooth address: B4:F1A:4D:69:E3 Wi-Fi MAC address: B4:F1A:BF:B3:04 SPC: 979314 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Trying third method...OK Reset FRP operation for SP320 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Writing loader...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.7 Software version. Last edited by abufares; 07-19-2018 at 15:47. Reason: The Problem the phone shut off before you able to reset and also no reset option on the phone |
07-19-2018, 16:27 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Put the device into Download (Emergency) Mode manually, select X210MA and try to perform "Reset FRP". Post here the result. |
07-19-2018, 17:20 | #9 (permalink) | |
Member: 848549 Status: Offline Thanks Meter: 9 | Quote:
Welcome to Octoplus FRP Tool v.1.3.5.0 Platform: LG Selected model: LMX210MA Put the phone into Download Mode: 1. Power phone OFF; 2. Press and hold "Vol+" button and connect USB cable. Searching for a phone. Please wait... Found phone on COM184 Reading info... Detected phone model: LG-SP320 Warning: Selected model (LMX210MA) differs from the detected one (LG-SP320)! Mode: Emergency Initializing.. SW version: SP32010f_04 Android version: 7.1.1 Reset FRP operation for LMX210MA will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partition... Detecting writing method... Trying to repeat.. Trying third method... Resetting FRP lock.. Writing loader... Trying to repeat.. Operation is not supported for your phone's firmware version. Performed by 1.3.5.0 Software version. | |
07-19-2018, 17:49 | #10 (permalink) |
Member: 848549 Status: Offline Thanks Meter: 9 | Checking data...OK Platform: LG Qualcomm Selected port: COM184 Selected model: LMX210MA Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Mode: Emergency Initializing flash...OK SW version: SP32010f_04 Android version: 7.1.1 LAF Version: 1.1 Product ID: CT67S171025001247 IMEI: 358226-08-171774-5 Target operator: SPR Hardware: rev_10 Reset FRP operation for LMX210MA will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 4... Step 5... Step 6... Step 7... Step 8... Step 9... Step 10...Failed! LAF Error: 0F0F0F0F. Reset FRP operation is currently not supported for your phone's firmware. Performed by 2.8.7 Software version. |
07-20-2018, 08:22 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. We have prepared test Software version for You. Try to reset FRP using test Software and post here the result. |
07-24-2018, 22:17 | #14 (permalink) |
Crazy Poster Join Date: Oct 2014
Member: 2280189 Status: Offline Thanks Meter: 10 | SP320 Reset FRP successfully done Welcome to Octoplus/Octopus Box LG Software version 2.8.7.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM76 Selected baudrate: 0 Selected model: SP320 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM76 Mode: Emergency Initializing flash...OK Model ID: LG-SP320 Platform: mt6750 Android version: 7.1.1 SW version: SP32010f_04 LAF Version: 1.1 Product ID: CT68S170920008538 IMEI: 358226-08-074327-0 Target operator: SPR Hardware: rev_10 Battery level: 4294967295% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 358226-08-074327-0 MEID: 358226-08-074327 Bluetooth address: 10:F1:F2:F5:07B Wi-Fi MAC address: 10:F1:F2:6A:A1:AE SPC: 040701 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Trying third method...OK Reset FRP operation for SP320 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock...OK Formating encrypt...OK Rebooting phone... Resetting FRP lock successfully completed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.7.6 Software version. Last edited by Octopus box; 07-25-2018 at 05:15. |
The Following 3 Users Say Thank You to Leo_systems For This Useful Post: |
07-24-2018, 23:42 | #15 (permalink) |
Junior Member Join Date: May 2015
Member: 2391510 Status: Offline Thanks Meter: 4 | SP320 Reset FRP done Welcome to Octoplus/Octopus Box LG Software version 2.8.7.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM171 Selected baudrate: 0 Selected model: SP320 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM171 Mode: Emergency Initializing flash...OK Model ID: LG-SP320 Platform: mt6750 Android version: 7.1.1 SW version: SP32010f_04 LAF Version: 1.1 Product ID: CT67S171026002058 IMEI: 358226xxx Target operator: SPR Hardware: rev_10 Battery level: 4294967295% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 358226xx MEID: 358226xxx Bluetooth address: B4:F1A:4D:CA:71 Wi-Fi MAC address: B4:F1A:C0:11:74 SPC: 813486 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Trying third method...OK Reset FRP operation for SP320 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock...OK Formating encrypt...OK Rebooting phone... Resetting FRP lock successfully completed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.7.6 Software version. Last edited by Octopus box; 07-25-2018 at 05:15. |
The Following 2 Users Say Thank You to nelopc For This Useful Post: |
