09-24-2019, 05:01 | #9 (permalink) |
Crazy Poster Join Date: Sep 2010 Location: honduras
Member: 1386786 Status: Offline Thanks Meter: 16 | MSL from logcat thanks XDA i didn't do much different then other phones i have pulled msl from in the past but this way was just tad different. I first opened settings, about phone, and tapped on build till it opened developer settings... then went to developer settings and unticked the auto update as i always do... ticked oem unlock... and debugging... i then hooked up to computer and and prepared "adb logcat -d > logcat.txt " in a command prompt window i chose to open in the adb directory of my windows machine. then i went to the dialer on the stylo4 and typed ##3424#to bring up the diag menu. i was then asked for the code. because i didn't have the code yet... i typed 00000 and before i hit the 6th 0 i started logcat from the command prompt i had prepared. i then quickly went back to phone and hit the 6th 0, o coarse it failed but i did it again and once more till it caused the phone to reboot. i then quickly stopped the logcat. i opened its file which was created in the directory i opened the command prompt in.. adb directory.. and began to search. i used the find option to try some of the key phrases i used in the past but wasn't able to find it with them, luckily, by chance i had ran into a string that had spc in it so started to investigate. that is when i found it.. so plain and clear.. my 6 digit code... here is what it looked like... 03-21 09:55:45.373 1377 1377 D RichInputConnection: commitText() : 1 03-21 09:55:45.375 2172 2265 D LGATCMDService: Request from remote!! 03-21 09:55:45.375 2172 2265 D LGATCMDService: [LGATCMD] request.opcode : 4056 03-21 09:55:45.375 2172 2265 D LGATCMDService: [LGATCMD] request.length : 0 03-21 09:55:45.375 2172 2265 D LGATCMDService: [LGATCMD] request.body : [B@9aac5ca 03-21 09:55:45.375 2172 2265 D LGATCMDService: [LGATCMD] request.body : 03-21 09:55:45.376 472 17086 D [email protected]: [LGATCMD] opcode : 4056, data_len : 0 03-21 09:55:45.376 472 17086 D [email protected]: [LGATCMD] data : 03-21 09:55:45.376 472 17086 I Atd : service_handler: opcode = 4056 03-21 09:55:45.376 472 17086 I Atd : [init_modem_interface] configureRpcThreadpool 03-21 09:55:45.377 472 17086 E : ---BpLGPService 03-21 09:55:45.377 662 696 E : TRANSACTION_LGP_SPC_READ 03-21 09:55:45.381 472 17086 E : ---> Proxy read : 1 03-21 09:55:45.381 472 17086 I Atd : Success to read spc value 03-21 09:55:45.381 472 17086 D [email protected]: [LGATCMD] result : 0, data_len : 7, status : 0 03-21 09:55:45.381 472 17086 D [email protected]: [LGATCMD] data : 708608 03-21 09:55:45.381 2172 2265 D LGATCMDService: [LGATCMD] response.result : 0 03-21 09:55:45.381 2172 2265 D LGATCMDService: [LGATCMD] response.length : 7 03-21 09:55:45.381 2172 2265 D LGATCMDService: [LGATCMD] response.status : 0 03-21 09:55:45.382 2172 2265 D LGATCMDService: [LGATCMD] response.response : [B@a35f33b Im not sure if color will show on this thread or not but i made my spc red for you to see it.. it was 708608. i think i have taken up much of your time already but thought i could maybe help someone..even just one person. i hope that you enjoy your msl/spc code and your stylo4. if you have any other tips, tricks or a list of hidden menu codes others may like, please share them. i will update and add ones i find as i do. thanks! |
The Following 5 Users Say Thank You to djcal1985 For This Useful Post: |
10-10-2019, 23:00 | #11 (permalink) |
Member: 1386786 Status: Offline Thanks Meter: 16 | Unlock already q710al but i have bugs no wifi no bluetooh RED: LTE no showing only working 2g, edge, H+ 3G emergency calling [IMG]https://1.bp.********.com/-GXR-HzHonOc/XZ-paHqlKMI/AAAAAAAACQ0/7RQjzdJKj-AGGAJOKj5FGyCN9VTZ9iGhgCNcBGAsYHQ/s320/Screenshot_2019-10-10-11-13-55.png[/IMG] https://1.bp.********.com/-WrDnhmeSv...0-11-14-13.png |
10-23-2019, 16:30 | #12 (permalink) |
Junior Member Join Date: Jun 2019 Location: Honduras
Member: 2915160 Status: Offline Thanks Meter: 0 | Hello djcal1985 congratulations by yours avances, can you explain the process, maybe we would help you to resolve the problems than you have now.. thank you |
