08-16-2016, 19:58 | #1 (permalink) |
Crazy Poster Join Date: May 2014
Member: 2179170 Status: Offline Thanks Meter: 2 | LG V10 (H901) FRP Error Checking data...OK Platform: LG Qualcomm Selected port: COM377 Selected model: H901 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-H901 IMEI: 000000-00-000000-0 Android version: 5.1.1 Battery level: 53% Mode: Emergency Initializing flash...OK SW version: LGH901AT-01-V20e-310-260-MAR-16-2016-ARB01+0 LAF Version: 1.1 Product ID: BS06S160111002073 IMEI: 354017-07-351989-0 Target operator: TMO Hardware: rev_10 Resetting FRP Lock...Failed! Error code: KLQWHCKASD Performed by 2.3.9 software version. |
08-17-2016, 13:06 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please check your PM, we have sent You a test Software version. Try to perform "Reset FRP" operation with test Software and post here the result. |
08-17-2016, 18:05 | #3 (permalink) |
Member: 2179170 Status: Offline Thanks Meter: 2 | Welcome to Octoplus/Octopus Box LG Software version 2.3.9.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: H901 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-H901 IMEI: 000000-00-000000-0 Android version: 5.1.1 Battery level: 44% Mode: Emergency Initializing flash...OK SW version: LGH901AT-01-V20e-310-260-MAR-16-2016-ARB01+0 LAF Version: 1.1 Product ID: BS06S160111002073 IMEI: 354017-07-351989-0 Target operator: TMO Hardware: rev_10 Resetting FRP Lock... Step 1...Failed! Error code: KLQWHCKASD Performed by 2.3.9.3 software version. |
08-18-2016, 19:53 | #5 (permalink) |
Member: 2179170 Status: Offline Thanks Meter: 2 | Welcome to Octoplus/Octopus Box LG Software version 2.3.9.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: H901 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-H901 IMEI: 000000-00-000000-0 Android version: 5.1.1 Battery level: 42% Mode: Emergency Initializing flash...OK SW version: LGH901AT-01-V20e-310-260-MAR-16-2016-ARB01+0 LAF Version: 1.1 Product ID: BS06S160111002073 IMEI: 354017-07-351989-0 Target operator: TMO Hardware: rev_10 Resetting FRP Lock... Step 1...Failed! Error code: KLQWHCKASD Performed by 2.3.9.5 software version. |
08-19-2016, 10:44 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please try to perform "Reset FRP" operation again, with new test Software version, which we've sent You in PM. |
08-19-2016, 17:51 | #7 (permalink) |
Member: 2179170 Status: Offline Thanks Meter: 2 | Welcome to Octoplus/Octopus Box LG Software version 2.3.9.7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: H901 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-H901 IMEI: 000000-00-000000-0 Android version: 5.1.1 Battery level: 40% Mode: Emergency Initializing flash...OK SW version: LGH901AT-01-V20e-310-260-MAR-16-2016-ARB01+0 LAF Version: 1.1 Product ID: BS06S160111002073 IMEI: 354017-07-351989-0 Target operator: TMO Hardware: rev_10 Resetting FRP Lock... Step 1...Failed! Error code: KLQWHCKASD Reading partitions...OK Resetting FRP Lock... Step 1...OK Step 2...OK Step 3...OK Resetting screen lock successfully completed! Performed by 2.3.9.7 software version. it took me to the main screen asking if I wanted to use Easy Home or regular Home screen, i went with regular, i doubled checked the back up to make sure it was disabled and no accounts where on it and after doing a hard reset it no longer has the Google Lock on it, seems to be doing alright now skipping the New User stuff and locks. THANK YOU!! |
