02-13-2017, 12:21 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: E a r T h
Member: 216094 Status: Offline Thanks Meter: 321 | LG v10 H961N flashing error Befoure Flashing Phone Is working Well . Problem Is Some Virus Issu App Download Its Self So We Try To Flash. Welcome to Octoplus/Octopus Box LG Software version 2.5.4 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM6 Selected model: H961N Reading info... Model ID: LG-H961N IMEI: 353829-07-042397-0 Android version: 6.0 Battery level: 100% SW Version: H961N20k Mode: Emergency Initializing flash...OK SW version: LGH961NAT-00-V20t-HKG-XX-DEC-15-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: YE03S151022000175 IMEI: 358xxxxxxxxxxxxx Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "H961N_V20h_00_0818.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...Failed! Performed by 2.5.4 Software version. Befoure Flashing Phone Working on H961N20t_00_1215_2. I Download Flash File From Support Area H961N_V20h_00_0818.oct And Flash After Error Writing PrimaryGPT...Failed Now Phone Is only Fimware Update Mode Even I Try To Hard Reset but Same. Need Soluation !!! Last edited by Octopus box; 02-13-2017 at 14:37. |
02-13-2017, 12:28 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. You have tried to downgrade firmware version from V20t to V20H, this is the problem: Quote:
02-13-2017, 12:34 | #3 (permalink) | |
Member: 216094 Status: Offline Thanks Meter: 321 | Quote:
Thankyou For Replay But I Have Also Try Same Fimware H961N20t_00_1215_2.oct its convert From Kdz But Same Error. | |
02-13-2017, 12:43 | #5 (permalink) | |
Checking data...OK Platform: LG Qualcomm Selected port: COM6 Selected model: H961N Reading info... Model ID: LG-H961N IMEI: 353xxxxxxxxxxxx Android version: 6.0 Battery level: 100% SW Version: H961N20k Mode: Emergency Initializing flash...OK SW version: LGH961NAT-00-V20t-HKG-XX-DEC-15-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: YE03S151022000175 IMEI: 35xxxxxxxxxxxxxx Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "H961N20t_00_1215_2.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...Failed! Performed by 2.5.4 Software version. | |
02-13-2017, 13:18 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to write the same V20t firmware using the latest Software version (Software). In the latest Software versions "Write firmware"operation for firmwares with signatures was improved. |
02-13-2017, 13:39 | #7 (permalink) | |
Welcome to Octoplus/Octopus Box LG Software version 2.5.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM6 Selected model: H961N Reading info... Mode: Emergency Initializing flash...OK SW version: LGH961NAT-00-V20t-HKG-XX-DEC-15-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: YE03S151022000175 IMEI: 353829-07-042397-0 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "H961N20t_00_1215_2.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...Failed! LAF Error: 80000121. operation is currently not supported for your phone's firmware. Performed by 2.5.8 Software version. SAME ERROR | |
02-13-2017, 14:47 | #9 (permalink) | |
Reson I convert kdz To Oct And Write That's Why I Got Error When I directly select KDZ and Write Flashing Smothly Done. Welcome to Octoplus/Octopus Box LG Software version 2.5.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM6 Selected model: H961N Reading info... Model ID: LG-H961N IMEI: 353829-07-042397-0 Android version: 6.0 Battery level: 100% SW Version: H961N20k Mode: Emergency Initializing flash...OK SW version: LGH961NAT-00-V20t-HKG-XX-DEC-15-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: YE03S151022000175 IMEI: 353829-07-042397-0 Target operator: GLOBAL Hardware: rev_10 Opening "H961N20t_00_1215_2.kdz"...OK Firmware version: LGH961NAT-00-V20t-GLOBAL-COM-DEC-15-2016+0 Firmware model: LG-H961N -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Verifying checkSums...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing 1/69 PrimaryGPT_0.bin...OK Writing 2/69 modem_16384.bin...OK Writing 3/69 pmic_196608.bin...OK Writing 4/69 sbl1_197632.bin...OK Writing 5/69 tz_199680.bin...OK Writing 6/69 sdi_201728.bin...OK Writing 7/69 hyp_202752.bin...OK Writing 8/69 rpm_203776.bin...OK Writing 9/69 aboot_204800.bin...OK Writing 10/69 sbl1bak_208896.bin...OK Writing 11/69 pmicbak_210944.bin...OK Writing 12/69 hypbak_211968.bin...OK Writing 13/69 tzbak_212992.bin...OK Writing 14/69 rpmbak_215040.bin...OK Writing 15/69 abootbak_216064.bin...OK Writing 16/69 sdibak_220160.bin...OK Writing 17/69 persist_278528.bin...OK Writing 18/69 sec_360448.bin...OK Writing 20/69 laf_376832.bin...OK Writing 21/69 boot_475136.bin...OK Writing 22/69 recovery_557056.bin...OK Writing 23/69 raw_resources_737280.bin...OK Writing 24/69 raw_resourcesbak_745472.bin...OK Writing 25/69 factory_753664.bin...OK Writing 26/69 system_901120.bin...OK Writing 27/69 system_1165448.bin...OK Writing 28/69 system_1429456.bin...OK Writing 29/69 system_1689736.bin...OK Writing 30/69 system_1693784.bin...OK Writing 31/69 system_1953744.bin...OK Writing 32/69 system_2214024.bin...OK Writing 33/69 system_2218072.bin...OK Writing 34/69 system_2478032.bin...OK Writing 35/69 system_2738312.bin...OK Writing 36/69 system_2742360.bin...OK Writing 37/69 system_3002320.bin...OK Writing 38/69 system_3262600.bin...OK Writing 39/69 system_3266648.bin...OK Writing 40/69 system_3526608.bin...OK Writing 41/69 system_3788752.bin...OK Writing 42/69 system_4050896.bin...OK Writing 43/69 system_4313040.bin...OK Writing 44/69 system_4575184.bin...OK Writing 45/69 system_4837328.bin...OK Writing 46/69 system_5099472.bin...OK Writing 47/69 system_5361616.bin...OK Writing 48/69 system_5623760.bin...OK Writing 49/69 system_5885904.bin...OK Writing 50/69 system_6148048.bin...OK Writing 51/69 system_6410192.bin...OK Writing 52/69 system_6668288.bin...OK Writing 53/69 system_6930432.bin...OK Writing 54/69 system_7192576.bin...OK Writing 55/69 system_7454720.bin...OK Writing 56/69 system_7456904.bin...OK Writing 57/69 system_7460952.bin...OK Writing 58/69 system_7979008.bin...OK Writing 59/69 system_7981192.bin...OK Writing 60/69 system_7985240.bin...OK Writing 61/69 system_8503296.bin...OK Writing 62/69 system_8765440.bin...OK Writing 63/69 system_9027584.bin...OK Writing 64/69 system_9289728.bin...OK Writing 65/69 system_9551872.bin...OK Writing 66/69 system_9554936.bin...OK Writing 67/69 cust_9674752.bin...OK Writing 68/69 cust_9936896.bin...OK Writing 69/69 BackupGPT_122141696.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.5.8 Software version. | |
02-13-2017, 14:52 | #10 (permalink) |
Member: 216094 Status: Offline Thanks Meter: 321 | But At Last I Stuck On FRP Checking data...OK Platform: LG Qualcomm Selected port: COM6 Selected model: H961N Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-H961N IMEI: 353829-07-042397-0 Android version: 6.0 Battery level: 100% SW Version: H961N20t Mode: Normal Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Resetting FRP Lock...Failed! LAF Error: 80000121. Reset FRP operation is currently not supported for your phone's firmware. Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.5.8 Software version. |
02-14-2017, 09:23 | #11 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
11-05-2017, 16:58 | #12 (permalink) |
Insane Poster Join Date: Feb 2016 Location: Lahore Pakistan
Member: 2531963 Status: Offline Thanks Meter: 12 | Model ID: LG-H961N IMEI: 353829-07-134555-2 Android version: 6.0 Battery level: 4% SW Version: H961N20t Mode: Emergency Initializing flash...OK SW version: LGH961NAT-00-V20t-HKG-XX-DEC-15-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: YE02S151226000119 IMEI: 353829-07-134555-2 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... LAF Error: 80000121. Trying second method...OK Resetting FRP lock successfully completed! Performed by 2.7.6 Software version. oct team plz help me i reset the frp v10 h961n its stuck on lg logo in log as you can see step 1 error and the step 2 clear frp but its stuck on frp |
