11-21-2016, 10:55 | #1 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2651577 Status: Offline Thanks Meter: 1 | LG V521 Resetting FRP Lock...Failed! [Solved] -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM50 Selected model: V521 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-V521 IMEI: 356286-07-XXXXXX-X Android version: 6.0.1 Battery level: 48% SW Version: V52110c Mode: Emergency Initializing flash...OK SW version: LGV521AT-01-V10c-310-260-JUL-21-2016-ARB01+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB41S160521005292 IMEI: 356286-07-XXXXXX-X Target operator: TMO Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! Reading partitions...OK Resetting FRP Lock... Step 1... Performed by 2.5.0 Software version. Last edited by Octopus box; 11-24-2016 at 09:45. |
11-21-2016, 11:02 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Reset FRP operation is currently not supported for the latest firmware, which is in your device (LGV521AT-01-V10c-310-260-JUL-21-2016-ARB01+0). We work on new Reset FRP method. As soon as solution will be ready, we will release it. |
11-22-2016, 12:39 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, download and install test Software version form the Support Area (LG/TEST SOFTWARE/) then repeat operation which You need again, post here full Software log. |
11-24-2016, 08:05 | #4 (permalink) | |
Member: 2651577 Status: Offline Thanks Meter: 1 | Quote:
-------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM52 Selected model: V521 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-V521 IMEI: 356286-07-XXXXXX-X Android version: 6.0.1 Battery level: 93% SW Version: V52110c Mode: Emergency Initializing flash...OK SW version: LGV521AT-01-V10c-310-260-JUL-21-2016-ARB01+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB41S160521005292 IMEI: 356286-07-XXXXXX-X Target operator: TMO Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...OK Resetting screen lock successfully completed! Performed by 2.5.1 Software version. Its work. Thanks!!! | |
04-22-2017, 07:57 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
Please post here full Software log with all performed operations, we will check it. Last edited by Octopus box; 04-22-2017 at 08:54. | |
04-23-2017, 05:10 | #7 (permalink) |
Freak Poster Join Date: Sep 2013 Location: Tepa,HnD
Member: 2033258 Status: Offline Thanks Meter: 61 | Well I had check the log I, not at home now but it seems that the device it's on the latest 7.0 and now I'm having a hard time on downgrading it. Any input will appreciate Sent from my iPad using Tapatalk |
