02-18-2017, 19:31 | #1 (permalink) |
Insane Poster Join Date: May 2016
Member: 2573221 Status: Offline Thanks Meter: 11 | LG V986 Flash Problem LG G3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM44 Selected model: VS986 Reading info... Model ID: LG-H811 IMEI: 352392-07-024883-1 Android version: 5.1 Battery level: 14% SW Version: H81110n Mode: Emergency Initializing flash...OK SW version: LGH811AT-00-V10n-TMO-US-AUG-17-2015-ARB02+0 Android version: 6.0 LAF Version: 1.1 Product ID: YE07S150506001979 IMEI: 352392-07-024883-1 Target operator: VZW Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Canceled! Performed by 2.5.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM44 Selected model: VS986 Reading info... Model ID: LG-H811 IMEI: 352392-07-024883-1 Android version: 5.1 Battery level: 14% SW Version: H81110n Mode: Emergency Initializing flash...OK SW version: LGH811AT-00-V10n-TMO-US-AUG-17-2015-ARB02+0 Android version: 6.0 LAF Version: 1.1 Product ID: YE07S150506001979 IMEI: 352392-07-024883-1 Target operator: VZW Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Canceled! Performed by 2.5.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM44 Selected model: VS986 Reading info... Model ID: LG-H811 IMEI: 352392-07-024883-1 Android version: 5.1 Battery level: 14% SW Version: H81110n Mode: Emergency Initializing flash...OK SW version: LGH811AT-00-V10n-TMO-US-AUG-17-2015-ARB02+0 Android version: 6.0 LAF Version: 1.1 Product ID: YE07S150506001979 IMEI: 352392-07-024883-1 Target operator: VZW Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Canceled! Performed by 2.5.7 Software version. Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM44 Selected model: VS986 Reading info... Model ID: LG-H811 IMEI: 352392-07-024883-1 Android version: 5.1 Battery level: 15% SW Version: H81110n Mode: Emergency Initializing flash...OK SW version: LGH811AT-00-V10n-TMO-US-AUG-17-2015-ARB02+0 Android version: 6.0 LAF Version: 1.1 Product ID: YE07S150506001979 IMEI: 352392-07-024883-1 Target operator: VZW Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "VS98626A_00_0615_ARB02.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing pmic...OK Writing sbl1...OK Writing tz...OK Writing sdi...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing pmicbak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing sdibak...OK Writing persist...OK Writing sec...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing factory...OK Writing system...Failed! Error code: ZXLCALSZXD Performed by 2.5.7 Software version. |
02-20-2017, 08:54 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. As i can see from the Software log, your phone model is H811, but You are trying to reflash the phone with firmware which declared for another phone model VS986. Please, check what phone model exactly do You have, check on PCB and try to reflash the phone with correct firmware file. |
