03-18-2017, 15:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | lg vs425 error write fimwarer [Solved] -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM452 Selected model: VS425 Reading info...Failed! Port busy Performed by 2.6.0 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM452 Selected model: VS425 Reading info...Failed! Port busy Performed by 2.6.0 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM450 Selected model: VS425 Reading info... Model ID: VS425PP IMEI: 352990-08-533578-0 Android version: 5.1.1 Battery level: 30% SW Version: VS425PP2 Mode: Emergency Initializing flash...OK SW version: LGK120AT-01-V10h-CRK-US-SEP-23-2016-ARB00+0 Android version: 5.1.1 LAF Version: 1.2 Product ID: CB47S170107004006 IMEI: 352990-08-533578-0 Target operator: VZW Hardware: rev_10 Performed by 2.6.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM450 Selected model: VS425 Reading info... Model ID: VS425PP IMEI: 352990-08-533578-0 Android version: 5.1.1 Battery level: 30% SW Version: VS425PP2 Mode: Emergency Initializing flash...OK SW version: LGK120AT-01-V10h-CRK-US-SEP-23-2016-ARB00+0 Android version: 5.1.1 LAF Version: 1.2 Product ID: CB47S170107004006 IMEI: 352990-08-533578-0 Target operator: VZW Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "VS425_V11A_03_ARB00.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing tz...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing tzbak...OK Writing rpmbak...OK Writing abootbak...OK Writing sec...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing factory...OK Writing system...OK Writing BackupGPT...Failed! LAF Error: 80000001. Performed by 2.6.0 Software version. Last edited by Octopus box; 03-21-2017 at 19:34. |
03-20-2017, 08:57 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. What is exact state of your phone? Why You have decided to re-flash it? What phone model exactly do You have? |
03-20-2017, 14:58 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Unfortunately, this VS425PP phone model isn't supported. You need to reflash the device with correct firmware for your phone model. Please, contact with us tomorrow, we will try to prepare test Software version for You. Last edited by Octopus box; 03-20-2017 at 15:04. |
03-20-2017, 18:34 | #6 (permalink) | |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Quote:
Enviado desde mi LGLS775 mediante Tapatalk | |
09-22-2017, 01:31 | #8 (permalink) |
Junior Member Join Date: Apr 2012
Member: 1748817 Status: Offline Thanks Meter: 0 | i Have a VS425LPP.. i flashed witn k121 firmware .. phone turns on but USB port no longer works.. phone won't charge or unlock.. i used p999 cable and was able to get into download mode.. but PC wont detect the phone.. how did you recover the phone? i have octoplus with medusa activation.. but MSM8909 is not supported.. please help |
09-22-2017, 07:40 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. You can try to repair your device with Medusa Pro Software via eMMC. |
