01-28-2016, 17:57 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1870650 Status: Offline Thanks Meter: 12 | LG VS985 can't connect I want unlock but I couldn't connect. there's no menu for PC Connection...Plz help To connect the phone in normal mode you need: Go to "Settings -> PC connection -> USB connection type -> Internet connection" and select "Modem"; Here's log... Platform: LG Qualcomm Selected port: COM1 Selected model: VS985 Reading info... Could not detect mode! |
01-28-2016, 18:19 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please install required drivers and restart PC. http://octoplusbox.com/files/drivers...Ver_3.12.3.exe, http://octoplusbox.com/files/drivers...dADBDriver.exe . Try to connect the phone again, after drivers installation, without changes in "PC connection" menu if it is missing. Also, select "Charge only" connection option, when You connect the phone to PC. |
01-29-2016, 17:33 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please, make sure that You Enable USB Debugging in the phone's menu, then select "Charge only" connection option, when You connect the phone to PC, after try to perform operation which You need, post here result. |
02-25-2016, 10:47 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please, make sure that You Enable USB Debugging in the phone's menu, then select "Charge only" connection option ( if You have Android 5.x), when You connect the phone to PC, after try to perform operation which You need, post here result. |
02-27-2016, 11:00 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please, install the Software latest Software version, select correct phone model, press Cable & Manual button and read software manual carefully. To connect the phone in Normal Mode, perform following steps: Type ##7764726 and press "Call" button; Input Serivice Code ("000000"); Go to "W2BI - TEST SETTING" and select "W2BI SETTING ENABLE"; Go to "Port check test" and select "Enable". |
04-02-2016, 19:48 | #11 (permalink) |
Insane Poster Join Date: Jun 2005 Location: paraguay, asuncion Age: 42
Member: 155935 Status: Offline Thanks Meter: 2 | but stiil not detect Welcome to Octoplus/Octopus Box LG Software version 2.2.4 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: VS985 Reading info... Could not detect mode! Performed by 2.2.4 software version. |
04-07-2016, 08:38 | #14 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
