09-05-2015, 20:39 | #1 (permalink) |
No Life Poster Join Date: Apr 2015
Member: 2385655 Status: Offline Thanks Meter: 99 | lg23 how to: reset pattern lock reset [Solved] Selected port: COM1 Selected model: L23 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info...Failed! Port busy Last edited by Octopus box; 09-07-2015 at 10:46. |
09-06-2015, 19:54 | #4 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | lg23 how to: reset pattern lock reset thanks octopes box my problem salove not loss deta only remove pattion pasward thanks for me click to thanks Platform: LG Qualcomm Selected port: COM208 Selected model: L23 Reading info... Mode: Emergency Initializing flash...OK SW version: LGL23AT-00-V10d-440-50-DEC-10-2013+0 LAF Version: 1.0 Product ID: PT01S140118002106 IMEI: 358380-05-057772-9 Target operator: KDDI Hardware: rev_10 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM208 Selected model: L23 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LGL23 IMEI: 000000-00-000000-0 Android version: 4.2.2 Battery level: 47% Mode: Emergency Initializing flash...OK SW version: LGL23AT-00-V10d-440-50-DEC-10-2013+0 LAF Version: 1.0 Product ID: PT01S140118002106 IMEI: 358380-05-057772-9 Target operator: KDDI Hardware: rev_10 Resetting Screen Lock... Resetting screen lock successfully completed! |
09-07-2015, 20:25 | #5 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | reset pattern lock reset Platform: LG Qualcomm Selected port: COM208 Selected model: L23 Reading info... Model ID: LGL23 IMEI: 358380-05-057772-9 Android version: 4.2.2 Battery level: 100% Mode: Normal -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM208 Selected model: L23 Reading info... Model ID: LGL23 IMEI: 358380-05-057772-9 Android version: 4.2.2 Battery level: 100% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...Failed! More than one device, connected via ADB, were found. Please disconnect all devices from PC and connect only the device You want to work with. |
09-09-2015, 14:32 | #8 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | lg23 how to: reset pattern lock reset [Solved] Try to write QCN file from the Support Area but how to write qnc? how to lg23 emergency mode buttons? and qnc write to emergency mode? |
09-09-2015, 14:38 | #9 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | lg23 how to: reset pattern lock reset [Solved] how to this mod buttons press?vol-/vol+ need infarmation [Q] Flashing Revolution firmware in Emergenc… | LG Revolution | XDA Forums |
09-09-2015, 15:45 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | To perform "Write QCN" operation, do the next: 1. Remove SD and SIM cards from the phone; 2. Connect powered-on phone to PC via Micro USB cable; 3. Press "Write QCN"; 4. Follow software instructions (prompts). Note: To connect the phone in Normal Mode, do the next: Go to "Settings -> PC connection -> USB connection type -> Select USB Connection method" and select "LG Software" ("PC Software"). |
